Engine Removal, what needs to be done?
Old Apr 20, 2007 | 02:53 PM
JD730's Avatar
Like the title says, what needs to be done to get the engine out of a 95?
And anything special that needs to happen too.
I've never done one and a friend of mine is about to so he needs to know.
Thanks in advance.
Old Apr 20, 2007 | 03:40 PM
Box5's Avatar
It's pretty much straight forward, just make sure everything is disconnected thats attatched to the truck, remove as much in the front as possible (radiator etc) and chain it up and lift it out.
Old Apr 22, 2007 | 09:30 AM
fschiola's Avatar
Double check the rating on your hoist, the engine is 1000# + .
Old Apr 22, 2007 | 10:38 AM
74dart's Avatar
Make sure you unplug and/or remove the temp sensor behind the fuel filter. If you break it its $55 dollars from the aftermarket. Don't ask me how I know this.
Old Apr 22, 2007 | 02:35 PM
Haulin_in_Dixie's Avatar
Well it has been put across as a bit simple. If it is 4wd it is a bit more complicated possibly the two wheel also. Take the valve cover off, remove the two valve adjusters and pushrods from the back of the engine. unbolt the mounts and raise the engine. Now remove the oil pan. When raised it will clear the pickup tube and slide out to the back. Now remove the pickup tube. Remove the air conditioning compressor. pull the radiator and intercooler. unbolt and remove the engine.
You will find that when removing or installing the engine if the air compressor is left on it is almost impossible to get the trans lined up.
Old Apr 22, 2007 | 07:02 PM
lews930's Avatar
wouldnt it be much easier to just lift the cab and hoist it out? thats how I do it. 1 hour last go around.
get as BIG hoist! motor is heavy.
Old Apr 22, 2007 | 07:05 PM
74dart's Avatar
took mine out with the head off but put it back in fully assembled without lifting the cab and with the ol pan in place.
Old Apr 22, 2007 | 07:18 PM
I can only say that you would not do that with my '99. Could not fit.....
Old Apr 22, 2007 | 08:04 PM
74dart's Avatar
It wasn't easy and if it has to be done again I will put it back in with the head off, But I hope I never have to pull the motor again.
VikingDiesel
Jan 8, 2007 11:04 PM
cowboys toys
Oct 23, 2005 08:49 PM
Rather b cummin
Mar 9, 2004 09:20 AM
Duck Hunter
20
Dec 9, 2003 05:36 PM
