Deadly CLICK
Old May 3, 2007 | 07:54 AM
Truckman's Avatar
Question Deadly CLICK
Morning ALL..
Bad time last night,,I think my VP-44 Died after 212000 miles,,,
I am in the process of changing it now,,, I was turning the engine over with the altenator nut to get the IP key way at 12 O clock,,when I heard a "SNAP" ..Now using the alt nut I see I was turning the engine over backwards,,What did I break??? It sounded plastic..
HELP...
I will be in and out of the house to check this post ...
OK More questions,,,,
I am installing a good used IP,, On my old pump it has a 035 key in it,, Now the used pump I am puttin in,stamped on the side is 046 where my original pump is stamped 035,, Will my 035 key work? Or do I need to get a 046 key for this pump?
I am thinking the CLICK I heard was in the old IP...Cause she dont turn to easy Now that it is out...
THANKS
Old May 3, 2007 | 09:09 AM
Need95-00CTD's Avatar
Thats wierd, my belt will slip if I try to turn the engine back even a hair...
For anyone who is wondering ti was when I did the GSK, and sure enough I passed the spring by about 20 thousanths and the retainer wouldn't come off...so I had to put the clip back on and turn the engine all the way back to the spring...instead of going back an 1/8 of a turn...
Old May 3, 2007 | 10:17 AM
Truckman's Avatar
Talking She Lives!!!!!!!!!!!!!!!!!!!
Contacted the guy I got the used pump from and he had the keyway I needed ,,, AND She RUNS AGAIN!!!!!!!..
Thank Goodness,,,
NO MORE TAPPING OF THE PUMP!!!!!!!!!!!!!!!!!!!!!!
Old May 4, 2007 | 12:39 PM
riolobo69's Avatar
sound like th tdc pin sound to me. Popped the tip off one myself.
marksmith
Aug 17, 2007 02:57 AM
Sleigher
Mar 23, 2007 12:23 PM
cheapskate
19
Dec 27, 2006 08:05 PM
PaulDaisy
Dec 2, 2006 12:36 PM
bnold
Apr 25, 2006 06:57 PM
