Cruise issues with EZ
Old Jun 8, 2006 | 12:03 PM
CSAGrey1's Avatar
I am posting this for a buddy of mine.
He has an 03HO 2500HD with auto. Only bombing done is a AFE stage 2 intake and an edge EZ. After the EZ install the cruise control is screwing up. If you set it to say 60 mph it will drop back to 56 then throttle back to 60 then drop again, so on and so forth. If you remove the EZ the problem goes away. The shop he purchased it from called Edge and they say they have never heard of such problems. Has anyone else experienced this? Is there a flash that will resolve the issue? Is it a faulty programer? Your input------
Old Jun 8, 2006 | 12:08 PM
P.J's Avatar
P.J
Pretty common problem. I would search "Cruise Surge" I believe there is a way to fix (or reduce) it by inserting an aresol spray can tube (WD40) in the vaccum line somewhere.
Old Jun 8, 2006 | 12:33 PM
scuzman00's Avatar
My 02 standard tranny truck intermittently has the same thing occur. Mine started with installation of my EZ. I have found that if you will turn cruise off then back on and re-set speed that it usually works fine.....
I don't worry too much about it though, cause down here in Houston, the ID10T in front of you invariably can't drive the speed limit or likes to ride his brakes.....
Gary
BaconGrainFarms
Jan 3, 2012 08:09 PM
SIZMTRS
Jan 14, 2008 07:30 AM
ILLINOISRAM
Jan 9, 2008 05:19 PM
trophystock
Jul 6, 2006 06:28 PM
Bobcat698
Nov 21, 2005 03:19 PM
