"check gages" light on
Old Mar 25, 2006 | 10:22 PM
dodgedriver's Avatar
My husband drives an '01 2500 diesel. Today on the highway the check gages light came on and the voltage dropped to the eight.....but the truck continued to run fine. We made it into town and even drove with the lights on. Any suggestions on what this could be? Hopefully nothing serious.
Thanks!
Old Mar 26, 2006 | 07:09 AM
high country's Avatar
as you will prolly learn this morning, the charging system is down. on that year truck you can cycle the key on/off/on 3 times and it will shoot you the codes in the odometer window, but 8v and check guages is going to be pretty striaght forward
Old Mar 26, 2006 | 07:34 AM
Shovelhead's Avatar
Administrator / Scooter Bum
He didn't just complete an oil & oil filter change did he?
Old Mar 26, 2006 | 08:44 AM
HdPower's Avatar
If the other items that the guys mentioned above doesn't work check and see if you have a loose battery cable, this is what the problem with mine was, also make sure your batteries are in good shape
Old Mar 26, 2006 | 05:54 PM
Rauschbo's Avatar
....could also the the CKP (Crankshaft Position Sensor)...did the Tach go to -0- or go haywire at all?
Old Mar 27, 2006 | 09:45 AM
Thanks for the replies.
He hasnt changed the oil & oil filter recently.
He cleaned the connections on the battery and checked the cables. He will be taking it and having the batteries checked this morning.
The Tach didn't do anything unusual that I noticed. I was the one driving when it happened.
I really hope it is just the batteries, or maybe it needs new cables.....I will post and let you know what he finds out about the batteries,
Thanks guys.
Dizzle
Jan 20, 2013 07:32 PM
swell01
Nov 22, 2009 07:39 PM
hotdram
Mar 14, 2007 08:18 PM
woodzy
Oct 8, 2006 11:06 PM
roadie00
Nov 9, 2004 07:35 PM
