check gages/temp gage
Old Nov 22, 2009 | 07:03 PM
swell01's Avatar
2001 stock auto. driving home temp gauge pins and check gauges light comes on. Then light goes off and temp gauge returns to normal. This happens twice and I notice that when gauge is pinned and light is on the heat is blowing cold. I'm guessing thermostat or water pump. I'm no mechanic but would like to have an idea of what the problem is before I get it fixed.Thanks
Old Nov 22, 2009 | 07:10 PM
mishkaya's Avatar
Are you low on coolant? I have seen this happen in that case. Could be as simple as a bad coolant sensor or corroded connection as well. Can't hurt to check the water pump and replace the thermostat though... Good luck.
Old Nov 22, 2009 | 07:35 PM
swell01's Avatar
I just checked the coolant. It was about 2 gallons low! I'm taking it on a test run. Now to find the leak. I haven't seen anything on the ground and I watch it close because recently there has been a puddle of PS fluid. just changed the steering box. Thanks for the help.
Old Nov 22, 2009 | 07:39 PM
Clunk's Avatar
Check your engine oil level in case coolant is leaking into the crankcase.
Coolant can ruin the bearings & crankshaft.
KartRacer
Feb 19, 2007 10:19 AM
woodzy
Oct 8, 2006 11:06 PM
dodgedriver
Mar 27, 2006 09:45 AM
JCROMAN
Mar 22, 2006 09:33 AM
Figlos
Feb 5, 2006 02:17 PM
