Changed Oil have problem....
ok I dont know what I just did I changed the oil & filter on my truck a few mins aro & now if I accellerate it sputters & blue smoke until it goes into the halfway area in the safe zone on the dipstick, it never did this before any ideas?<br>it blows a ton of blue smoke out the taiul pipe till it get down to this level on the dipstick soI assume it;s burning it...<br><br>DRecu! Please Help!<br>
Re:Changed Oil have problem....
Drecu, I'm not a cummins mech, but I talked to one where I work as he was leaving. He suggests that you try going back to the original filter. He said that if the new one was plugged somehow that if your pump was really puttin out it would force the oil out. Just passing along what he said. Good luck.<br>Ed
[quote author=Shovelhead link=board=13;threadid=16470;start=0#154475 date=1056831359]<br>My '99 takes 11 qts with an oil filter change to hit the high mark on the dipstick.<br>[/quote]<br><br>What Ed said... 10 in the crank and one in the filter and you should be right at the high mark on the dipstick!
K guys! Sorry I did not get to you guys sooner & thanks a bunch cherod, anyways it was the filter & it was a K&N which I am never buying again, figured it would be a good filter right, guessnot I put the old wix back on & the truck is fine so i'm going out to return the K&N & buy another Wix or Fleetguard I never thought a filter could cause such wierd problems, anyways make a note to yourself not to buy a K&N Oil Filter for your truck I know I am not.<br>I am glad though that it was notheing else that got damaged by this filter.<br><br>DRecu<br><br>again thanks to sherod I would probably not have thought of the filter. 8)
[quote author=drecu link=board=13;threadid=16470;start=0#154694 date=1056909019]<br>K guys! Sorry I did not get to you guys sooner & thanks a bunch cherod, anyways it was the filter & it was a K&N which I am never buying again, figured it would be a good filter right, guessnot I put the old wix back on & the truck is fine so i'm going out to return the K&N & buy another Wix or Fleetguard I never thought a filter could cause such wierd problems, anyways make a note to yourself not to buy a K&N Oil Filter for your truck I know I am not.<br>I am glad though that it was notheing else that got damaged by this filter.<br><br>DRecu<br><br>again thanks to sherod I would probably not have thought of the filter. 8)<br>[/quote]
<br>Might be extreme, but try to keep a cancelled reciept with your maintenance records JUST IN CASE.
ontheedge
13
Apr 1, 2008 04:59 PM
Puke
Jun 7, 2006 06:09 AM
silverram323
Oct 10, 2003 12:19 AM
Farmout
13
Jun 24, 2003 03:15 PM
