A/C problems
A/C problems
I am having problem's with my a/c,thought maybe somebody else may have had this problem.The switch that operates the speeds only works on high,and sometimes if you turn the defroster on it will keep blowing there even if you move to another position.need help bad high is to much need my other three positions.i have a98.Thanks Dave
Re:A/C problems
Dave,<br>Just a thought, it sounds like you have a bad blower motor resister block. If the other resisters are burnt out then the blower will only operate on high. It's a very common problem on Fords.<br>Dean
