broke down again crank no start
Old Dec 20, 2008 | 08:51 PM
  #31
CMooreBLKSMK's Avatar
Originally Posted by TOM R
at idle i am pushing 20+ psi on the gauge
another Q when the truck is cycling in warm up mode how low should the volt gauge go?
What what gauge?
And when my grid heater cycles it will sometimes pull the volt gauge down just low enough for the check gauges light to come on.
Cory
Old Dec 20, 2008 | 09:46 PM
  #32
TOM R's Avatar
found the ecm, who the heck mounts a computer to the side of a diesel engine, talk about vibration
Old Dec 21, 2008 | 06:52 AM
  #33
dozer12216's Avatar
Well everyone has beat the bushes to death trying to avoid the inevitable.
Put a VP44 on an be done with it. Trying to figure the codes will run you in circles so many times.
Old Dec 21, 2008 | 10:46 AM
  #34
TOM R's Avatar
yup thats what figured truck has 195,000 miles and I am sure it was replaced at least once so ...
Old Dec 22, 2008 | 01:39 PM
  #35
TOM R's Avatar
this may be another symptom of my problem, I have been starting the truck and letting it run for about 20 minutes at a time so the batts don't die since it has been in the 20's here but i have not driven it for fear of another breakdown and it is too cold out for any manual diagnosing, I am noticing that the truck is smoking out the exhaust and smells like rich exhaust, i never had this before at least not a idle, is this a symptom to my problem or is it just cause it is so dam cold out?
Old Dec 22, 2008 | 09:24 PM
  #36
J BODY's Avatar
Yeah!! just like the guy posting in the 2nd gen forum that just replaced his VP.......and his truck still DOESN'T run
Old Dec 22, 2008 | 11:00 PM
  #37
johnh's Avatar
yes there is definitly a ton of info here wich is a great thing to have access to, now on the adding a relay isn't that what the relay in the fuse box under the hoods for? if needed i could add another one though
i agree there is a lot of information out there, but the problem is applying it correctly to the issue... this is where the mechanic with his experience and equipment comes in...you cannot beat a correct diagnosis
Old Dec 26, 2008 | 12:57 PM
  #38
TOM R's Avatar
Originally Posted by BigIron70
P0230 Transfer Pump Circuit Out Of Range
Here is test procedure if you want to try and diag yourself. I would think transferpump most likely bad.
ok i did this test and it says replace tranfer pump which i did already and perform powertrain verification test ver-2a, what is this?
Old Dec 28, 2008 | 06:01 PM
  #39
TOM R's Avatar
ok well I drove the truck around today for the first time since the last breakdown and it seems fine but it was in the 50's yesterday and 60's today so i think maybe fuel geling was the problem? when I broke down it was 15* during the day and i don't add antigel so guess i should start
Old Dec 29, 2008 | 07:37 AM
  #40
patdaly's Avatar
Tom, anything is possible, the new ULSD gells much more quickly than the old stuff. After a good year last year, the MFGs. may be trying to lower the additive levels to reduce costs.
This could see-saw back and forth until they get their collective stuff together, the first year of ULSD was a nightmare for most people in cold weather, we had stuff frozen up all over.
I just automatically dose it double strength with white PS whenever I fill up.
Old Dec 29, 2008 | 08:38 AM
  #41
TOM R's Avatar
well i guess all i can do is add the antigel and drive her, if she breaks doen again I know it wasn't the feul
92smokin blacky
May 17, 2011 06:50 PM
TOM R
Jan 16, 2009 03:40 PM
TOM R
Dec 18, 2008 10:34 AM
dieselfumes57
16
Nov 7, 2008 09:15 AM
CoolumConst
Oct 11, 2008 10:00 PM
