pile of junk is broke down again.
Old Oct 28, 2008 | 04:25 PM
dieselfumes57's Avatar
4 p0191 codes in 2 days and stalling under acceleration and fuel pressure drops to 3 to 5k every few minutes and then jumps up to 15 to 17k. I stopped and changed fuel filter and it made no differance. Filter was clean anyway. Rt befored i hit my driveway it would hardle run and pull the hill to the house. Does this sound like a Lift pump? please help........work is piling up and my truck is broke down.
Old Oct 28, 2008 | 05:00 PM
Ram Daddy's Avatar
Wink
"Does this sound like a Lift pump? "
...does to me.
Old Oct 28, 2008 | 05:17 PM
CD in NM's Avatar
P0191 code is in reference to your RAIL PRESSURE, could be the RP relief valve (I think that's what it's called). I had that code several times when my truck was new, the dealership replaced the valve.
After those few times I had the code, I installed the DiPricol rail pressure gauge. I also carry a 'bolt' to plug it off just in case I have problems out in the middle of nowhere and it stay's 'relieved' and no fuel pressure or a minimum of pressure.
CD
Old Oct 28, 2008 | 05:30 PM
i have reset the code a couple times and still does the same thing or runs the same way and then the light comes back on
Old Oct 28, 2008 | 05:58 PM
just ordered an airdog 150 to see if it fixes my prob. should i attempt to install this thing? how hard is it to install and how long does it usualy take?
Old Oct 28, 2008 | 06:56 PM
bluechrome's Avatar
It is fairly straight forword. should take about 4hrs if you take your time
Old Nov 5, 2008 | 11:33 PM
Cuminapart's Avatar
Air Dog it , (150) AND FORGET IT! check that relief though ,to be sure!
Old Nov 6, 2008 | 12:09 AM
madhat's Avatar
Administrator/Jarhead
I would reccomend pulling the bed if you have 3 friends to help... 3 bolts on either side (4 if it's a long bed), 2 wire connectors, and one gound wire. I have dropped the tank and pulled the bed, pulling the bed was much easier.
Old Nov 6, 2008 | 06:59 AM
tcr's Avatar
tcr
Sounds to me to be FCA or RP sensor related w/ the RP jumping around like that.
Old Nov 6, 2008 | 06:02 PM
if the rp sensor goes out will it still run? its throwing a code eveyr few days now
Old Nov 6, 2008 | 09:05 PM
BigIron70's Avatar
Cummins Guru
Bad Fuel rail pressure sensor.
Using the scan tool, monitor the actual fuel pressure reading while the key is on and engine is not running. Is the actual fuel pressure reading greater than 870 psi? If it is replace the sensor.
Old Nov 6, 2008 | 09:45 PM
at idle its around 6500 to 7k and maxes at 23k
Old Nov 6, 2008 | 09:51 PM
i did airdog it....kinda wish i would have went factory. installed airdog and now its running fine but ad 150 seems to be getting air or something. makes a constiant noise and then a louder noise ever few seconds, sounds like its leaking air some somewhere. all the hoses r tight and i added clamps on the fittings and stll no help. i think the rings in the fitting are leaking. its just opnion but i think they should have made these with a solid fitting not swivel.
Old Nov 6, 2008 | 11:37 PM
madhat's Avatar
Pull the filters and throw some lube on them (oil) and then tighten them back down, see what that does.
Old Nov 7, 2008 | 07:00 AM
did that on install.....thanks though
