Broke down crank no start
Old Dec 17, 2008 | 04:46 PM
TOM R's Avatar
ok i broke down friday engine just shut off, no fuel pressure but pump was running, got the replacement pump installed now i got fp but she won't run, i know i am gettin fuel to the inj pumpcracked the #3 or 4 line at the valve cover and no fuel even when cranking, am i doing something wrong? do i need to open all the lines? did my vp44 die?
Old Dec 17, 2008 | 04:56 PM
TOM R's Avatar
I also have a p1698 code and am waiting for the snapon scanner to show up to check the rest
Old Dec 17, 2008 | 05:10 PM
05Pilot's Avatar
I always start @ # 6 and work my way forward and some times you will have to wiggle the lines to make sure the seal is broke between the connector tube and line. It may take a little bit but it should get her running
P1698 No CCD/J1850 Message From TCM No CCD/J1850 messages received from the electronic
transmission control module (EATX) or the Aisin
transmission controller.
Old Dec 17, 2008 | 05:14 PM
TOM R's Avatar
so do I loosen em and just cycle the key or crank till theres fuel?
I tried doing a search for the code but started finding too many things from crank sensor to cam sensor to bad computer to burnt vp44 harness etc. that could be a problem for that code
Old Dec 17, 2008 | 05:29 PM
John Faughn's Avatar
Do not put parts in without testing to know what you need , now with that out of the way , its common with the vp pump that when the lift pump goes out [ the motor can run , but not pump fuel ] , that the vp will run enough to start , then that shortens the life of the vp / working too hard .
Just noticed the gauge in your sig. , did you see the fuel pressure go before/as it died .
You may want to put your location , in case a member is in your area , may help ?
Is that your original vp pump ?
Try disconnecting the box's .
Do you have fuel pressure with the new pump [ gauge showing ] , then do a pressure test at inlet to vp .
Old Dec 17, 2008 | 05:53 PM
TOM R's Avatar
ok just got back in from workin on her more, had 1,3,4, loose had dad crank while I watched, got fuel on 4 then 3 then the truck tried starting, tightened them got fuel at 1 tightened it and she finaly fired and stumbled for a few seconds and is now running, back in july i saw the gauge dropping intermittent so I replaced the lp before doing damage this time it was early morning driving and the engine just shut off no gauge flux or engine stumble, looked down at the gauge and 3 psi or less, had her towed lp was running but no fuel getting to the filter so figured the impeller came off the pump motor,took a few days for the new pump but it was replaced free,this airtex only lasted 4500 miles
i am in south jersey near philly
thanks for all the help, my buddie just bought this same truck in a 3/4 ton he is lucky i am learning to do all this before he has problems lol
Old Dec 17, 2008 | 06:42 PM
cLAYH's Avatar
I'm a HD mechanic by trade and my '01 is one of the most difficult engines to bleed that I've ever worked on!
In contrast my '03 is by far the easiest! No need to crack injectors. Just crank.
Old Dec 17, 2008 | 07:42 PM
TOM R's Avatar
ususaly when I change out the fuel filter i can fire it up then it dies then I crank it a few times and eventualy it starts and runs
Old Dec 17, 2008 | 09:46 PM
cLAYH's Avatar
I've never had a problem with the filter either but after doing injectors with dry lines, whole different story.......
Old Dec 18, 2008 | 10:34 AM
TOM R's Avatar
ok i am broke down again p1693 code and the truck was hard to get started this morning, driving and the tach started freaking out then shut off no restart had to be towed again, I have 20 psi on the fp gauge did my vp44 go? and where do i get one?
pquevill
Jul 19, 2011 08:18 PM
92smokin blacky
May 17, 2011 06:50 PM
TOM R
Dec 29, 2008 08:38 AM
CoolumConst
Oct 11, 2008 10:00 PM
bsj04
Feb 18, 2008 06:06 PM
