With a boost elbow, does the wastegate still function?
Old Mar 1, 2006 | 09:43 PM
GlennRMK's Avatar
Thanks
I sprayed water around there and couldn't come up with anything
This is a PIA
Old Mar 1, 2006 | 11:22 PM
DR3500's Avatar
are you sure your gauge is good?
Old Mar 2, 2006 | 12:15 AM
GlennRMK's Avatar
Definitely seemed to pull harder before
Old Mar 2, 2006 | 02:27 PM
GlennRMK's Avatar
Found the leak!
Found my boost LEAK!
Had to crank my air compressor up to about 25 lbs to see it.
Its the intake manifold gasket. Luckily that is covered on the engine warranty so it will be going in Wednesday.
If it wasn't I would be waiting and doing injectors at the same time as it looks like you have to pull all the injector lines to get it out of there.
Thanks for help guys!
atch
Nov 1, 2010 02:45 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
MoparRiggan
Oct 13, 2005 11:54 AM
G-NOTE
Aug 31, 2005 07:48 PM
Lrdchaos
Aug 30, 2005 06:45 PM
