bad belt!!!!!!!!!!!
Old Oct 8, 2009 | 07:22 PM
ale440's Avatar
Belt trouble !!!!!!!!!!!!!!!!!!!!1
2004.5 3500 4wd the belt every 30000 miles chews off a rib then i put a new one on cant figure out why any ideas
Old Oct 8, 2009 | 07:29 PM
I'd replace the tensioner assembly.
Old Oct 8, 2009 | 07:37 PM
06RAM2500's Avatar
Do the idler pulley bearing also.
Old Oct 9, 2009 | 12:20 PM
Busboy's Avatar
Have a look at all the grooved pulleys, sometimes there can be something stuck in one of the grooves like a small rock, piece of metal, that kind of thing. Also as previously mentioned check your idlers as a bad bearing or bad tensioner can also cause this.
Old Dec 10, 2009 | 07:35 PM
ale440's Avatar
thanks for the tips
Old Dec 15, 2009 | 11:40 PM
06RAM2500's Avatar
What did you get figured out??
Old Dec 16, 2009 | 12:16 AM
Colo_River_Ram's Avatar
With age comes the cage
Does your truck have a belt chirp at shutdown?
Do a search for the overrunning alternator pulley or belt chirp..
Here is the TSB from Genos Garage:
http://dodgeram.info/tsb/2006/09-004-06.htm
Old Dec 18, 2009 | 11:44 AM
dj_souvlaki's Avatar
Ya check the pully's. most likely cause by either a bad bearing or a missaligned pully. while you are at it throw on a gator back good year belt. world of a difference
Old Dec 18, 2009 | 12:39 PM
BigIron70's Avatar
Cummins Guru
Also check water pump bearing for play, release belt tension and check for any up and down play. There should be none, if there is it could cause belt to walk outward on pulley causing belt to chafe on pulley.
Old Dec 18, 2009 | 03:48 PM
LeaperV12's Avatar
You got a p/n for this belt bro ? or a place where i can find one.
thanks
DodgeDiesel61
Jan 26, 2019 07:45 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
apwatson50
Mar 3, 2006 06:26 PM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
