Vp 44
Old Dec 17, 2009 | 06:07 PM
jeremy12's Avatar
Vp 44
Having problems my trucks starts bucking under load. Checked injectors thought one might be stuck. All ok. Still having same problem. No codes.
Old Dec 17, 2009 | 10:54 PM
780_erickson's Avatar
Have your supply pressure to the injection pump checked ASAP, more than likely a bad lift pump, pressure should be a minimum of 7 psi, if it is you need to repace your lift pump or your injection pump will become ruined VERY quickly.
Old Dec 18, 2009 | 10:00 AM
mini14's Avatar
is your tach going to zero while its bucking ? could be cam or crank sensor.
Old Dec 18, 2009 | 04:49 PM
jeremy12's Avatar
I have a raptor 150 it is set at 15psi never goes below 7psi even at wot. Tach never varies more than 50-100 RPM.
Old Dec 18, 2009 | 05:50 PM
johnh's Avatar
what is your rpm when it bucks?
