Accelerator Pedal Position Sensor (APPS)
Old Aug 26, 2003 | 08:38 AM
jdeereboy's Avatar
Re:Accelerator Pedal Position Sensor (APPS)
For what it is worth, I removed the APPS and tested it here at work. Apparently, it is a Hall effect sensor. Hall effect switches and sensors rarely fail, so I am told. I plan to do some more research to see who makes the sensor.
Old Aug 26, 2003 | 10:46 AM
slayerfish's Avatar
I talked to a local tech who wrote an article for G.E.A.R.S magazine(american transmission repair assoc.) and he claims oftentimes the APPS signal is clean until it enters the ECM then it gets noisy-then when it gets to the PCM is where the trouble starts.Luckily mine is still working fine after reflash(8k mis.)Those little noise filters sound intriguing.
Old Aug 26, 2003 | 01:29 PM
Copenhagenjunkie's Avatar
On my truck it happens at about 30-35mph and usually coasting going down hill in town. Maybe I should try the reflash as it happens everyday on the same hill so I have just been putting tranny in neutral and braking more :. I am not at the point where I am going to buy and new APPS from the dealer.
Old Aug 27, 2003 | 09:42 PM
Scubasteve's Avatar
[quote author=Copenhagenjunkie link=board=13;threadid=11816;start=15#msg176880 date=1061922579]
[/quote]
My truck was doing this for the last 6 months. I finally broke down and put the APPS on it and problem solved.
Jason
Old Aug 27, 2003 | 10:57 PM
javi's Avatar
This sounds like a possible safety issue. Has anyone thought about reporting to the National Highway Safety Administration (see their site), known by the acroninm: NHSA, and see if they will force the company to recall the part. Alternatively, there is the possibility of a class action agaisnt the company for putting out a defective product. I believe this to be a safety issue more than a mechanical problem.
Old Aug 28, 2003 | 11:01 PM
Skipperl76's Avatar
The Noise Problem is ********.... Isolation of noise didn't help me a bit....neither did a 480.00 APPS....come on guys this is bad info to the Computer....then the computer just keeps on passing bad instructions.
Old Aug 31, 2003 | 11:49 PM
Ranch Hand's Avatar
I had the reflash done and it worked good for about 3000 miles but now its back just not as bad yet.
At 40-45 the TC locks and unlocks if I'm just trying to hold a steady speed(in town) but if I'm accelerating to highway speed it does fine. Even with the overgrive off it does it only at a lower speed. Befor the reflash it did it at most any speed.
jeramy125
Jul 1, 2009 08:46 AM
gofastman
Feb 1, 2006 05:57 PM
swktk1
Jun 26, 2005 09:23 PM
herb
Mar 11, 2004 05:50 PM
Diesel fitter
Feb 17, 2003 09:39 AM
