pedal position sensor
Old Jun 30, 2009 | 03:38 PM
jeramy125's Avatar
anyone know where to find the pedal position sensor on a 2003 2500? the cable runs to a spring on a housing on the motor. is it inside the housing??
Old Jun 30, 2009 | 04:08 PM
Grit Dog's Avatar
It is that whole piece with the return spring on it. Called the APPS by Dodge and bell crank or bell crank sensor by Cummins. Search APPS or P2121 or P2122 and you'll get some reading material.
Old Jul 1, 2009 | 07:43 AM
Peterbilt's Avatar
On 03/04 it's either under the plastic cover by the intake (with the tv cable) or under the battery. I forget which. Someone will chime in. If I get a chance today I will look it uop in the sm.
Pete
Old Jul 1, 2009 | 08:46 AM
Grit Dog's Avatar
'03 is right under the plastic cover where the throttle cable disappears. About 6 bolts to take it off and 1 plug underneath it (6 wires) that you can barely get your hand to to unplug it.
600 Megawatts
Mar 26, 2008 07:09 PM
Crazyhorse
Nov 24, 2007 04:07 PM
Ldyluck113
Dec 19, 2005 06:06 PM
swktk1
Jun 26, 2005 09:23 PM
tishmael
Aug 31, 2003 11:49 PM
