95 TD fuel leaking
Old Feb 11, 2003 | 09:33 PM
flip67's Avatar
95 TD fuel leaking
I recently bought a 95 TD 4x2 with 70,000 miles I noticed about a week after buying it that it leaked fuel. The leak is coming from one of the two braided hoses that go up to the motor under the drivers side. Ive had it for over a month and its gotten worse. I went to the dealer thinking it was the line itself and gave them the tag number from the line and they couldnt figure out wich one I needed so po?ed I left and the problem is getting worse I noticed today that it is leaking around the bellhousing. Please help.
Old Feb 11, 2003 | 11:19 PM
TBGH's Avatar
Re:95 TD fuel leaking
There are 2 fuel lines. The first line is a 3/8 supply and the second is a 5/16 return line. Change both and make sure to use deisel fuel rated hose. Two feet of each will be plenty. The job is a pain.<br>
Old Feb 12, 2003 | 06:25 AM
Smokee's Avatar
What TBGH said about the lines. Note that it is not likely the braided hoses that are leaking, but the rubber hoses (that you can't see) that conect to the hoses.<br>george
lilsuzuki4x4
Sep 1, 2011 01:50 AM
diablo1
Nov 11, 2008 10:30 PM
txasylum
Mar 22, 2008 02:47 PM
Gumby
Jan 24, 2005 01:15 PM
