4x4 Grinding when engaged
Old Jan 6, 2007 | 04:33 PM
kwpatton's Avatar
Originally Posted by DrDiesel
I would wait. If they pull the front diff. cover and there is damage, that`s a waste of oil. If not, have them add it when they refill and not charge you for the fluids.
yeah, but if its covered under warrenty they shouldn't charge me for fluids right....
Old Jan 6, 2007 | 06:58 PM
DrDiesel's Avatar
Exclamation
Yes. If there is damage. Other than that. It`s on you.
Old Jan 6, 2007 | 08:07 PM
kwpatton's Avatar
Yeah, good point....
Old Jan 6, 2007 | 11:18 PM
XLR8R's Avatar
Don't forget to remove your bombs before persuing warranty!
Old Jan 7, 2007 | 07:40 AM
JKM's Avatar
JKM
You could have damage to the front diff.
Sound`s like Spyder Gear issue`s to me. When you turn and wheel speed changes/differ`s from side to side, that`s when the spyder gears are active.
In this Case it would also do it in 2wd , as the wheel speed still changes.
Old Jan 7, 2007 | 08:10 AM
kwpatton's Avatar
Are you talking about any mods?
Old Jan 7, 2007 | 11:03 AM
XLR8R's Avatar
Yep - the dealer will raise an eyebrow at your lift and fueling box, etc. when you try to use the warranty.
Old Jan 7, 2007 | 12:19 PM
kwpatton's Avatar
Yeah, I'll take the fuel box off but not the lift and tires...
Old Jan 7, 2007 | 09:47 PM
DrDiesel's Avatar
Lightbulb
This is true, but without the load from the pinion gear it might not make the noise. If you have a better Idea as to what it might be, I`m sure he would like to hear it.
Old Jan 8, 2007 | 08:28 AM
kwpatton's Avatar
Well, so I drove my truck again this weekend through a field with the four wheel drive engaged and of coarse there is no problem at all. I changed all fluids in the diffs and the transfer case. All fluids and gears looked great for having 60K on them. I am starting to think the four wheel drive is fine and the binding is just coming from the change is wheel speed with oversize tires. The last think I want to do is go to the dealer and get a bunch of money wrapped up into nothing...
Old Jan 8, 2007 | 11:01 PM
Sootblower's Avatar
For peace of mind: jack up both front tires, block rear tires, put transfer case in Neutral and spin each front tire individually with steering wheel turned to max left or right (engine off). This makes axle U-joints work maximum and any binding will show. Put steering wheel dead center and compare relative resistance(U-joints do not work at all in this position). Should be relatively same resistance as when wheel cranked to max. You will quickly note any problems.
Old Jan 9, 2007 | 09:12 AM
kwpatton's Avatar
I will do that. Sounds like a good test to perform on my own. Thanks, Sootblower
snowjoker
Jan 7, 2009 11:22 AM
artieb
Jan 18, 2008 04:04 PM
Nate-03 D
24
Dec 6, 2007 08:05 PM
Backwoods
13
Feb 15, 2006 08:00 PM
cLAYH
Feb 6, 2004 10:59 AM
