4x4 engaged light not workin
Old Jan 6, 2009 | 07:38 AM
snowjoker's Avatar
My 4wd light has stopped, but its got power on the one side of the bulb socket, but nothing happening. Any suggestions on how to solve this problem or where to look for it ?
Old Jan 6, 2009 | 10:48 AM
bigragu's Avatar
If the bulb itself is good, the 4x4 engages, then the problem stems from I believe the 2 wire sensor that sits on top of the transfer case. It is the 4x4 transfer case switch, Mopar part # 04210979. Mine did the same, and after checking everything like you did, that was the fix. I bought straight from the dealer because local NAPA could not get me the correct sensor. They kept giving me the speedo sensor. Good luck.
Old Jan 6, 2009 | 11:15 AM
snowjoker's Avatar
Thanks Bigragu I actually grounded the oppposite wire that had no power and the light come on but stayed on while the truck was in 4wd till i shut the key off. I will check that switch.. and keep ya posted.
Old Jan 6, 2009 | 11:56 AM
CaptainChrysler's Avatar
I am voting for the switch too. Mine comes on and off as it pleases in 4WD. I removed it and tried to clean the gunk out of it and it did work better for awhile.
Roughly what does the switch cost?
Old Jan 7, 2009 | 10:56 AM
bigragu's Avatar
The switch was pricey- I want to say around 40 bucks from the dealer.
Old Jan 7, 2009 | 11:22 AM
Big Red 97''s Avatar
In my 2nd gen. My light dont work either but i know when its in 4wd and when its not. So i will keep my $40.
3ton1/4
Mar 18, 2009 03:11 PM
artieb
Jan 18, 2008 04:04 PM
Nate-03 D
24
Dec 6, 2007 08:05 PM
kwpatton
Jan 9, 2007 09:12 AM
Backwoods
13
Feb 15, 2006 08:00 PM
