4X4 engaged circut?
Old Jan 17, 2008 | 01:18 PM
artieb's Avatar
4X4 engaged circut?
Hi, I pretty much got most of my gremlins worked out in my rig. What I would like to have working is the 4X4 indication lamp ( possible female use). On the 205 I had a closure on the switch when engaged, bulb good. Where does this circuit start from and what connectors may be in trouble? I'm guessing Batt is sent to the transfer case and closed and goes to the bulb with a simple ground? Too easy or does it get complicated, like sending Batt through the bulb and grounding the NO switch on the transfere case switch? Thanks, Artie
Old Jan 17, 2008 | 01:39 PM
cootz's Avatar
Hopefully this helps.
These schematics are in the Sticky.
Old Jan 17, 2008 | 06:32 PM
artieb's Avatar
Thanks, Cootz, I looked up more info in the stickys. The 205's switch, also, does something with the RWAL module. I would assume that when engaged, the RWAL is disabled? Would this be a TRUE statement? Thanks for the direction, Artie
Old Jan 17, 2008 | 08:03 PM
cell's Avatar
Anyone have a part number for the actual indicator light?
Old Jan 18, 2008 | 04:04 PM
The bulb is a 158.
Moobesor
Sep 17, 2008 10:09 AM
bazdad
Feb 27, 2008 08:01 AM
electrifried
Oct 11, 2006 04:37 PM
Backwoods
13
Feb 15, 2006 08:00 PM
dncoy
Aug 26, 2004 10:33 PM
