2002 Parking brake help
Old Jan 13, 2008 | 09:51 AM
MikeBC's Avatar
OK,
So I'm in middle of my parking brake change, I have the calipers off, but how do I get to the drum to replace these little shoes I have?
It has the rear disc brakes, those are fine, just the e-brakes are gone, any ideas??
Old Jan 13, 2008 | 10:35 AM
MikeBC's Avatar
Well, If I take off the hub bolts (8 I think) the 1/2 shaft slides out. I didn't take it out far, didnt seem right to have to do that to change the shoes. So, I did a search here, doesnt seem this has come up before. I wish I knew who fried the parking brake, it should have lasted forever!
Old Jan 13, 2008 | 10:47 AM
mishkaya's Avatar
Hello
Looking at the service manual, it says simply to remove the calipers and rotors for the disc brakes, then to disengage the parking brake cable and remove the shoes. There is a diagram, but it doesn't show anything in particular. I can only assume that the drum for the parking brake is also part of the rear rotor. I don't know for sure as I have never had to touch the parking brakes on my '02.
Hope this helps some.
mishkaya
Old Jan 13, 2008 | 10:50 AM
mishkaya's Avatar
Sorry, didn't realize you have a dually most likely. For that the manual states to remove the rear axle shaft from the housing indeed. Good luck.
mishkaya
Old Jan 13, 2008 | 10:57 AM
slim51015's Avatar
On 3500 I think
You have to remove the axle then remove the big nut . 2 9/16 or 3 9/16 socket.
Remove the bearing then the rotor should slide off. There's a locking clip it the nut next to the treads, pry it out.
Old Jan 13, 2008 | 11:09 AM
MikeBC's Avatar
Mishkaya,
Thanks for looking it up, but the rotor seems to be one piece with the hub thats bolted to the axle 1/2 shaft. I've gotta be missing something here, I just cant imagine the rotor is all one piece. It's a 1 ton dually, and it's pretty massive looking
Attached Thumbnails 2002 Parking brake help-dsc00590.jpg   2002 Parking brake help-dsc00589.jpg   2002 Parking brake help-dsc00588.jpg
Old Jan 13, 2008 | 11:54 AM
mishkaya's Avatar
I only have a 2500 and it's quite different, but the manual shows the rotor/drum assembly separate from the hub, but it's all bolted together from the inside of the drum (torque for that is 95 ft. lbs by the way).
Sorry I can't be of more help.
mishkaya
Old Jan 13, 2008 | 12:57 PM
MikeBC's Avatar
WOW!! I got her done, but yep, you have to take the 1/2 shaft out, then the bearings!!! I woulda never guessed.........
THANKS everyone for your help
dochawken
Jun 29, 2012 01:04 AM
cnielsen4130
Jan 2, 2010 02:28 PM
bulldog_bones
Sep 9, 2009 01:53 PM
broncobilly
Nov 10, 2007 07:58 PM
Pete Miller
Dec 22, 2005 07:45 PM
