What is diesel ping?
Is it the same as in a gas engine, pre-ignition? I seem to have a very faint ping under very light accelleration that has been with me for a good part of the year - right after I went back to my usual fuel station and their brand of ULSD. Curious as to what it might be. I seem to be the only one that notices it.
The 'ping' is just the nature of a compression-ignition beast. The same basic concept would be carnage for a gasser, but is what makes the diesel world go around. Poor fuel and/or lack of additives in said fuel can make the diesel 'knock/ping' louder, but it's not an abnormality by any means. Driving an over-valved truck, you should be used to lots of noise There may be some 24v issues causing the intermitent ping that those more in tune with your truck can help with. Here's your bump
Muted User
Use higher cetane , like used in PS additive.It makes such a difference I can tell when I forgot to put the PS in my tank, my engine has more rattle, which OK by me though.
Diesels use heat ignition - very high cylinder temperatures ignite the fuel - cetane is the rating for self-ignition
Gassers (patooie!) use spark ignition - oil in the combustion chamber carbonizes at combustion chamber temps, as do other combustion by-products, which deposit on the piston crowns and heads - if those deposits become hot enough, gasoline will ignite long B4 the timed spark is delivered - that is ping, or Dieseling - octane is the rating for resistance to self-ignition.
That additive stuff dissolves and burns off the deposits during the normal spark-ignited combustion cycle - in theory, of course
__________________
__________________
Try 1/2oz ashless 2-stroke motor oil\gal fuel - that'll quiet it down, considerably, and is formulated for combustion chamber service, so your mileage may improve a little
dimarcoda
09-24-2004 01:10 PM
