Sponsored by:
Sponsored by: CARiD
transmission ?
Old Feb 4, 2010 | 08:08 PM
fast1939's Avatar
transmission ?
i no that the 94-95 dodge truck has a 47rh what transmission came in the 90-93 style.also on a 94 dodge ram 2500 front diff what side is the pumpkin on if you are looking at the truck from the front.
Old Feb 4, 2010 | 08:35 PM
Intercooled trucks had the 46RH aka 518. Same as a 47RH but the converter does not lock. Non-intercooled trucks had a 727 (no OD or lockup converter).
Diff is on the driver side, opposite a 1st gen.
Old Feb 4, 2010 | 08:44 PM
fast1939's Avatar
can a first gen transfer case be hooked to a 47rh out of a second gen 4x4
Old Feb 10, 2010 | 01:23 PM
SIXSLUG's Avatar
QUOTE]can a first gen transfer case be hooked to a 47rh out of a second gen 4x4[/QUOTE]
I would imagine not if the pumpkins are opposite.
Old Feb 14, 2010 | 09:44 AM
JD730's Avatar
Yes the NP205 from a first gen will bolt right up to a 47RH tail housing, in fact the A518 and 47RH use the same rear housing. The only thing you need to do is pull the seal out of the rear housing and use RTV to seal the flange.
Old Feb 14, 2010 | 01:30 PM
SIXSLUG's Avatar
Sorry I misread the question. Yes it will bolt up, would it be usable in a 2nd gen truck...probably not, unless you can rig up some sort of crossover driveshaft to the front diff!
Dauntless
15
Aug 30, 2016 08:37 PM
dsl-nut
Mar 22, 2003 12:12 PM
quantrill88
Mar 19, 2003 05:04 PM
harleydog
Mar 13, 2003 07:34 PM
jonesr2
Oct 12, 2002 04:49 PM
