Post-turbo EGT: Word from on high
Since installing a pyrometer on the "work truck" listed in my signature, I've been a bit concerned about how hot the EGT gets. I was poking around on Cat's website and saw the Cat Call Center section with an email address, so I asked them how hot the EGT should get. Here's their reply:<br><br>Dear Sir,<br><br> Thank you for contacting Caterpillar. The 1200rpm figure you mention below for shifting only applies to our heavy duty engines. The 3126 reaches it's peak torque at 1440 so you should be looking to downshift around 1500. Exhaust temperatures at that rpm are expected to be 1155 degrees and 1164 degrees at 2200 which is at rated horsepower. You should see a temperature of around 1167 at 1800rpm.<br><br>I guess I'm going to stop worrying about it until it hits 1200! They must have a helluva cooling setup on the pistons.<br>
Guest
Posts: n/a
Re:Post-turbo EGT: Word from on high
Just for your info. My probe is about 7 inches post turbo. I took my temps up to around 1000 quite a few times, but only for short periods. Then I was tooling up a long mountain climb, again around the 1000 degree mark, except this time for probably a good 4 minutes. Needless to say, rebuilding the engine, and about $9000 fixed that mistake! :-[ :'(Now if it gets to 950, I back her down.
Yikes, that was costly. Mind if I ask why you dont move the probe to the pre-turbo possition? I did on mine and it is alot more accurate. There is quite a difference in temp readings that way.
chadsdodge
Dec 24, 2007 11:17 PM
jmccart
Mar 18, 2007 10:03 PM
Dusty Ratcliff
37
Nov 30, 2006 05:21 PM
jmccart
14
Nov 20, 2006 06:45 PM
Oct 26, 2003 01:29 PM
