Sponsored by:
Sponsored by: CARiD
Old diesel fuel in 50 gallon fuel tank/tool box
Old Apr 24, 2010 | 05:11 PM
The_Head's Avatar
I have a parts truck that has a tool box/fuel tank. I want to install it in my current truck. I put fuel in it in July 2008. Is it still good? What should I do with it? How would I go about cleaning the tank?
Old Apr 24, 2010 | 05:17 PM
whiteeye42's Avatar
if it was me i would pump the old fuel out then take the tool box /fuel tank to the car wash and power wash it rinse it out really good and let it dry then start using it.
Old Apr 24, 2010 | 07:52 PM
reblerider20's Avatar
DTR'S RESIDENT NIGHT MECHANIC AND WELDER
sound like you got 50gals of parts cleaner to me
Old Apr 24, 2010 | 11:41 PM
tempforce's Avatar
if you were in my area, i would pump the old fuel out for you. my '83' ranger burns anything as long as it's filtered.
Old Apr 25, 2010 | 12:06 AM
CamperAndy's Avatar
Filter it and use it. Once you have used it all then cut the filter apart. If the filter is dirty then steam the tank out and have maybe have it coated, if the filter is clean then just use the tank.
Old Apr 25, 2010 | 10:04 AM
cougar's Avatar
Pump some into a clean bucket through a filter and see what it looks like. If it's dark or cloudy, don't use it.
Old Apr 25, 2010 | 02:00 PM
I bet it's fine.
Old Apr 25, 2010 | 05:54 PM
Nick02Ram's Avatar
I would think you could put 10-15 gal at a time to your tank and mix it with new diesel and it would be fine
Old Apr 25, 2010 | 07:41 PM
Raspy's Avatar
The fuel is fine as long as it doesn't have water and algae in it. Diesel is not like gasoline. I've run fuel that might have been as much as thirty or more years old. No problem.
Old Apr 25, 2010 | 11:32 PM
6cylinders's Avatar
I used 150 gallons of 18 month old fuel, no problems.
Old Apr 27, 2010 | 07:14 AM
powerrammaster's Avatar
Good question. I have a similar issue. Some of the fuel i have may be as much as ten years old. I did notice it was pretty dark after filtering. It is off road red, which I would use in my plow truck(not on road). Does any one see any prob using it mixed with some fresh after filtering to 10 micron, and water separation and some Power service? Using in a first gen.
Old Apr 27, 2010 | 02:39 PM
Jeff in TD's Avatar
In a P pump truck, I suppose I'd filter it and run it. Adding a bit to each tank wouldn't be a bad idea either.
In the CP3, though, I don't know if I would risk it, especially if you don't have a 2 micron filter. 6 injectors would be pretty pricey.
Old Apr 29, 2010 | 10:54 PM
The_Head's Avatar
I do remember adding power service to it when the truck was running, so maybe it's still ok.
Dodgezilla
Nov 6, 2011 04:13 AM
Mkinner
Sep 21, 2010 07:57 PM
chariotdriver
Oct 18, 2008 10:50 PM
Great_big_juan
Oct 1, 2007 01:01 PM
iwanactd
Dec 1, 2002 10:50 PM
