Oil Pressure Transmitters
Old 09-17-2013, 07:09 PM
cougar's Avatar
In general for an experiment.
I need a 100-150psi oil pressure transmitter with 3 wires; power, ground, and output. Ground can be through the case, but I'd prefer it wasn't. 1/8npt. Been looking at a bunch of them, but no one gives any electrical specs. Non automotive ones get real expensive real fast. There has to be something out there. Any suggestions?
Old 09-17-2013, 08:17 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Why not give these guys a call they might have what you need.
Or use a trans pressure sensor they go up to 300 psi.
http://www.astsensors.com/oem-pressure-sensors.php
Old 09-18-2013, 09:18 AM
cougar's Avatar
A price quote of $273 is way out of my range.
No one gives any specs for trans and oil pressure sensors. Looks like the transmission ones don't have pipe threads.
Old 09-18-2013, 10:45 AM
infidel's Avatar
http://www.summitracing.com/search/p...water-pressure
Old 09-18-2013, 04:59 PM
patdaly's Avatar
What level of precision do you require?
Old 09-18-2013, 06:04 PM
cougar's Avatar
Nothing special, just a linear output. I can use an analog (0-5vdc) output, but they are too expensive ($100++) for an experiment. Unless I can find a cheap used source. The only cheap 1 I found can't handle the up to 250° fluid temp it may be subjected to.
Old 09-19-2013, 09:23 AM
patdaly's Avatar
Easy then, as others have pointed out, just get a factory oil pressure gauge sender, it should be rated to your temperatures. A FSM should give you the ohm range to correspond pressure readings to.
Old 09-19-2013, 10:21 AM
cougar's Avatar
Not that easy, no one publishes the specs and there are several variations as to how they are wired. I need something that works like a potentiometer and I need access to all the connections like our TPS.
Old 09-20-2013, 12:09 PM
.boB's Avatar
a three lead pressure sender is used as a stock part on GM vehicles.
Trying to find the exact specs on it will be difficult, if not impossible. But it would be cheaper to build a test rig and map it yourself, than it would be to find a scientific pressure sensor that's already mapped for you.
http://www.summitracing.com/parts/smp-ps308
You can also buy a pressure transducer from Racepak. But they're not cheap. $180 for the transducer, or $250 for the transducer plus the signal box.
Old 09-21-2013, 11:49 AM
cougar's Avatar
The problem I am finding with the 2 and 3 wire senders is that 1 or 2 of the wires is for a low oil pressure switch for the warning light. Got to check out several with an ohm meter last night at a parts store. Looks like my only option is a $$$ transducer.
Due to a lack of finances, this project will have to go in the closet with the others.
Old 10-11-2013, 01:44 AM
bartming's Avatar
I want to start in conserving oil. Many people are in search of ways to cut costs on weekday meals, and a crock pot is a great solution. The best meals from a crock pot take just minutes to throw together and use inexpensive ingredients, and crockpots themselves cost less than a meal out. No matter what you like to eat, a crock pot can mean a complete meal with less than 20 minutes work.
Old 10-11-2013, 05:05 AM
BILTIT's Avatar
What exactly are you trying to do with the sensor? What type of electrical circuit?
I could probably send you an old transmitter from our site but they are 2 wire/24v/4-20ma output.
4-20ma can be converted to 1-5V with just a resistor.
I am guessing shipping would be over $100 anyways though.
Power Ram 250 C
02-20-2007 11:08 AM
D2 Cat
02-02-2007 03:22 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
Quick Reply: Oil Pressure Transmitters
