A little webasto help
Not sure if anyone has the access to the information I need. I got a webasto thermo 90 S coolant heater off of a loader at work. The unit is fully functional , I even fired it up and let it run a little while before I started removing it. I have the chance to buy it very cost effectively. The problem is it came off a 24V machine. I searched google for a while , and found install/operation manuals , as well as repair manuals all in PDF , and they all refer to the thermo 90 c as 12/24 volts, what I need to know , is will it operate on either voltage , or are there two different models, one for 12 and one for 24V. The only infomation I could find on the heater itself was on the circulation pump , and it read 24V (but it is mounted down by the engine) I found no indication of a source voltage requirement on the heating unit itself.
Does anyone know what one of these units is worth new/used (this one is not very old at all , and in excellent condition,) It is rated at 31 000 BTU at full heat, so it is LOTS of heat to warm up a little B series
It's already removed , it came off of a 24V machine ( a Cat 966C loader) What I need to know is will this unit (aside from the circulation pump) operate on either voltage?
If I get time I am going to hook up the electrical to a spare 12 volt battery and see if it will work, but I don't have a lot of spare time at work.
No need to worry about this one guys, I bought the unit from my boss at lunch time for 200$ , left it sitting beside the air compressor. A customer came in and saw it there ,asked the boss if it was for sale, the boss said he had already sold it to me , so the customer came and without knowing how much i bought it for , offered me 1000$ for it.
Needless to say my cummins will continue getting plugged in on the cold days
I sense a way to make extra pocket money , we are forever removing fire suppressions , heaters ,revolving lights, and all sorts of little thingamajigs that someone has bolted onto a piece of crap we bought at work
, there is a scale out of a 966E loader sitting in a box on a shelf , removed it because the customer buying the machine didn't need it. those scales are worth a few grand IIRC.
I have two ansul fire suppression systems now , 250$ each , and neither of them has ever been Activated. I am licensed to install fire suppression too.
, there is a scale out of a 966E loader sitting in a box on a shelf , removed it because the customer buying the machine didn't need it. those scales are worth a few grand IIRC.I have two ansul fire suppression systems now , 250$ each , and neither of them has ever been Activated. I am licensed to install fire suppression too.
Now, use that and buy the proper webasto..or espar.
Nah , that money is already spent, between my lawyer bill ( long story short , i won , cop could not provide evidence against me
) and now I have to pay someone to work on my truck because I just don't have time to do it myself anymore...
We only had one solid week of temps that stayed blow -20 this winter , anything above that I don't have a need to plug in. But for a couple hundred bucks i would install a heater.
) and now I have to pay someone to work on my truck because I just don't have time to do it myself anymore...We only had one solid week of temps that stayed blow -20 this winter , anything above that I don't have a need to plug in. But for a couple hundred bucks i would install a heater.
MOREPOWER
Aug 8, 2005 09:48 PM
HOHN
Mar 31, 2005 06:35 PM
