Sponsored by:
Sponsored by: CARiD
JD Diesel skipping at high idle
Old Feb 24, 2006 | 06:52 AM
TIMMY22's Avatar
I'm having trouble with a JD 1020 Diesel late model.
The engine has less than 1000 hrs. lately, when you bring the RPM's up above say 1800 it seems to have a faint skip.
it idle's fine and runs smooth below 1800.
it also has a little whiteish gray smoke up over 1800 but none at idle.
timing?
Old Feb 24, 2006 | 09:00 AM
jkitterman's Avatar
Do you work this tractor or drive it like Ms. Daisy? Are you current on reg maintence like filter and fluid changes?
Old Feb 24, 2006 | 10:12 AM
MJDiesel's Avatar
Is that a little 3 cylinder diesel that you have in that thing? My dad has a 1020 gas with a 3cyl.
Old Feb 24, 2006 | 10:27 AM
infidel's Avatar
My 2020 runs a little rough if you run the rpms up with it just sitting there. Put a load on it, even just moving and it runs perfect.
You could have a plugged up fuel filter.
Old Feb 24, 2006 | 10:54 AM
TIMMY22's Avatar
i tried the fuel filter, no change.
i just moved the timing about 1/16" rotation toward the block.
perfect! It has more response now too!
Yea, a little 3 cyl. diesel. I just did a rockshaft valve overhaul on it also.
and changed the motorola alternator to a "one wire" delco.
next, i'm working on an international 424 gas. It has a 1 1/2 inch pipe thread off of the exhast manifold. every time I try to thread a new piece of pipe into the manifold, it strips the threads off. can I buy a 1 1/2" tap from a plumbing store?
Old Feb 24, 2006 | 11:09 AM
G1625S's Avatar
''and changed the motorola alternator to a "one wire" delco.''
I read that the 1-wire delco 10-si will only charge when spun over 3000 rpms--have you found it to be a problem when just putting around? I put a 10-si 3-wire on my '50 Super A and it charges like a champ at 1600 rpms. Just curious.
Old Feb 24, 2006 | 03:39 PM
TIMMY22's Avatar
they have low rpm and high rpm styles.
Old Feb 24, 2006 | 03:49 PM
TIMMY22's Avatar
http://cgi.ebay.com/ebaymotors/ONE-W...40990927QQrdZ1
Old Feb 24, 2006 | 07:11 PM
infidel's Avatar
A quality 1-1/2" pipe tap lists for $176.18 at Grainger.
Sort of doubt you'll find one at Home Depot.
Might want to check with some rental outfits or buy a Chinese one like this http://www.harborfreight.com/cpi/cta...emnumber=42431
Old Feb 27, 2006 | 06:21 PM
TIMMY22's Avatar
I called a local plumbers supply that i deal with all the time, they had a loaner they let customers use. I used it over the weekend and got her all tappped out again.
kicker210
Dec 2, 2009 08:23 AM
parttime379
Mar 6, 2009 10:42 PM
jmccart
Jun 12, 2007 02:12 PM
ollieman
Feb 8, 2004 03:31 PM
1ST GEN.
Nov 20, 2002 01:35 PM
