skipping at idle
Old Mar 4, 2009 | 08:52 PM
parttime379's Avatar
skipping at idle
1999 2500 4x4 24 valve
my truck has started skipping at idle while in park and neutral,put it in gear and it goes away anybody have a clue to the cause of this.it doesnt do it all the time but it seems to be getting worse.it runs fine going down the road no skip or sluggish responses to the fuel pedal.also the truck is idleing at 900 rpm's is there a way to turn the idle down?
Old Mar 4, 2009 | 09:01 PM
darrenw's Avatar
check your fuel psi, your lift pump maybe going out.
Old Mar 5, 2009 | 05:58 PM
Dinner's Avatar
Do you mean almost like a misfire when you say skipping?
Old Mar 5, 2009 | 06:11 PM
yeah thats correct
Old Mar 5, 2009 | 10:36 PM
mini14's Avatar
Check Apps voltage on the sticker and then check actual apps voltage, if out of spec adjust apps. Sounds like it could be an idle validation prob in the apps.Your idle should be 750. Or you could just order a new apps but they are rather pricey.
http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old Mar 6, 2009 | 08:47 PM
thanks alot mini14
Old Mar 6, 2009 | 10:42 PM
67HotRod's Avatar
Mine was doing the same thing, stopped with the new vp44.
TIMMY22
Feb 27, 2006 06:21 PM
hairy bean bag
Jun 30, 2005 05:25 PM
jimrob
Aug 1, 2004 07:59 PM
ollieman
Feb 8, 2004 03:31 PM
1ST GEN.
Nov 20, 2002 01:35 PM
