cummins weight
cummins weight
Was just curious as to the weight of the cummins enging.How would that compare to a ford v-10. Looking at throwing one in my Excursion.Was wondering about the weight on front axles. Thanks for any replys. Todd
Randy
The diesel is most likely heavier, but your in luck. The Excursion was available with the Powerstroke so you could just upgrade the front springs if you needed to and you'd be all set! Just check the front axle rating which i'm sure is more than enough. Can't wait to see it!
I would love to do that myself (if I had an excursion and an extra Cummins...), I think that would be a very cool set up. Though the excursion is a tad too big for me, think its possible to squeze one in an expidition?
7.3 is definitely better than the 6.uh-0. But that's not saying much.
The link I posted above doesn't have the PSD weights...but in looking around I saw 1040 lbs...which is right about the same as the cummins for weight.
Purplezr2
07-25-2011 04:31 PM
