Sponsored by:
Sponsored by: CARiD
Case tractor with 4BT , delayed start...
Old Apr 28, 2005 | 12:05 PM
JKM's Avatar
JKM
Anyone got some tips/things to check? Started this winter i assume, but we couldn't tell be because it was cold , but now with temps up , when you try to start the tractor in the morning , it rolls over for an extended period of time before it finally fires (up to 10 seconds), after that first start , it is fine for the rest of the day. Does this sound like an air leak to anyone?
thanks for the help.
Jayme.
Old Apr 28, 2005 | 07:07 PM
Yes, it sounds like an air leak to me. What pump does the motor have? If it's the inline pump I'd look at the return carefully.
Old Apr 28, 2005 | 08:35 PM
JKM's Avatar
JKM
Nope , VE style pump. filters were changed in the winter , so i suspect one of them, 2 spin ons and one inline , my money is on the inline , give em all a turn tomorrow and tighten the clamps , i hope that helps it.
Old Apr 28, 2005 | 11:29 PM
Hemi Cat's Avatar
Most likely air getting into the system. Isn't that system gravity fed? Check your oil for diesel. You may have a seal gone on the pump. or the transfer pump.
Old Apr 30, 2005 | 01:19 PM
96_12V's Avatar
Does it make any differance to give it, say 1/4 to 1/3 throttle while cranking it. Could be that (as an air leak would do) it's bleeding back slightly overnight.
Old Apr 30, 2005 | 09:12 PM
JKM's Avatar
JKM
No , the system is not gravity fed , the fuel tank is under the cab , way below the engine, giving it throttle made no difference.
Tightening the clamps on the lines around the inline filter made everything 20X worse , after sitting for 5 minutes there was a slight delay in the start , after an hour it would crank for 20 seconds sometimes, so i pulled the rubber fuel lines today ( ) replaced them , i'll show you some pictures tomorrow of how bad it got, i think i definetly solved the problem, it worked fine all afternoon , true test will be tomorrow morning.
Old May 1, 2005 | 05:40 AM
Pentastar's Avatar
There is almost certainly a check valve in the fuel line,some of them can be disassembled for inspection and cleaning.I have repaired a Case W20 loader with a Cummins engine with the same symptoms without replacing any parts,just cleaning that check valve. Ron
Old May 1, 2005 | 01:28 PM
JKM's Avatar
JKM
No check valve , unless it is in the lift pump or downstream somewhere , replaced the fuel lines yesterday , went out this morning , temp at about 5 deg, no manifold heaters on the tractors , just either, but with no either , hit the key , it rolled the first cylinder over compression , second one came up and she fired off. for a 4 cyl with 7000+ hard hours on it , i think she still starts pretty good, and it is nice knowing my problem is fixed.
dgarner1988
Nov 8, 2012 06:39 AM
gaskin28
Oct 11, 2012 06:09 PM
gaskin28
Jul 23, 2007 09:50 PM
JollyGQ
Mar 26, 2007 06:36 PM
Bando
Jan 19, 2007 08:27 PM
