Sponsored by:
Sponsored by: CARiD
Blower on a diesel? could it be done? If so..why not?
Old Jul 25, 2009 | 11:09 PM
  #31
53 willys's Avatar
I got nothing really helpful to add....But I can tell you 2 stroke Detroit diesel's sound AWESOME!!!!
Old Jul 27, 2009 | 06:05 PM
  #32
benroberts3605's Avatar
https://www.dieseltruckresource.com/...l-t240201.html I posted this a while back
Old Jul 27, 2009 | 07:35 PM
  #33
Riflemanusmc's Avatar
Registered user
Nothing new. Volvo did it on their boat engine's. Series 40's. Blower over a turbo. Worked on a ton of them in AK... Fairly simple if you look up the specs............
Old Jul 28, 2009 | 02:48 PM
  #34
Mark Hodowanec's Avatar
Originally Posted by .boB
Ask your buddy if he's ever heard of a GMC 6-71 blower. Back in the fiftys and sixtys, hot rodders took the blower off of a diesel bus engine and adapted it to their gas engines.
TEchnology has advanced, and the belt driven blower has been left behind for most diesel applications. They are heavier, don't last as long, and are less efficient. I have seen some trick high performance and severe duty applications that have both a turbo and a belt driven blower.
The problem with a belt driven blower is that you get X boost at Y rpm. It's a fixed ratio. Loaded or unloaded, you get the same boost. And it's tough to get boost at low rpm's on a gas engine.
Watch the boost gauge on a turbo'ed anything. You get boost according to engine load. Cruising empty down the highway at 1800 rpm's you get 1-2 psi of boost. But start pulling a load up a hill, same speed and same rpm's, now you have 25-30 psi of boost.
More boost means more air volume. That increased air volume needs an increased fuel volume to keep the ratio the same. That's more important in a gas engine than in a diesel. That means the belt driven engine will burn pretty much the same fuel at that rpm regardless of load. The diesel engine will burn much less fuel, because of the lower boost.
Look at modern engine designs that are on the cutting edge - like Ford's new Ecotec engine. Lots of power, very efficient. Blower or turbo? Of course, it's a turbo.
Tell your buddy that you can easily put a blower on a diesel. But you don't want to lose that much power.
Best explanation on this subject I've read!
Old Jul 28, 2009 | 05:13 PM
  #35
daddy mopar's Avatar
In the Coast Guard I used to work on Detroit 6V92TA engines that were equipped with a turbo for high RMP's and a Blower for low RPM's, there was an oval bypass valve that determined which was primary and secondary for the work load of the boat.
These were newer 4 stroke engines!
Old Jul 29, 2009 | 10:09 AM
  #36
DetroitDiesel71's Avatar
From: Dayton, NJ (temporarily while In USCG on Staten Island)
the 6v92ta is still a two stroke, not a four stroke. Detroit did not go 4 stroke until series 40, 50 and 60's. The blower is on every detroit regardless of turbo or not. so the last post of it being for low rpm is off. it pumps at all rpms, providing air through liners, for combustion, and to push exhaust out the exhaust valves. Detroits are exhaust valved only. The coast guard uses the 6v92 ta DDEC which is way underpowered for the size of boat it is in.
Old Jul 31, 2009 | 10:39 PM
  #37
Registered user
^^ What the member said. Big differance between two and four stroke. ALL detroit two bangers have blowers. Volvo boat engine four strokers used a blower over turbo. Blower was used on the low end untill the turbo spooled...
Jim Lane
Apr 5, 2020 06:03 AM
sgrooms
21
Apr 8, 2008 11:17 AM
mainer
Oct 23, 2007 02:42 PM
Ramdriver15
Jan 24, 2007 09:33 AM
twistingawrench
Sep 15, 2006 04:44 PM
