UH OH!!! Tranny is done done... Will not shift to second gear...
Old Jan 14, 2007 | 06:25 PM
Ramdriver15's Avatar
uh oh!!! tranny stopped working today!!!!! I was driving dow the road today and the tranny downshifted to 2nd gear. Now i have no reverse and the tranny is only shifting to 2nd nothing else.
IM GONNA DIE!!! Just fixed the Power Steering, now this!!! it was running fine then idk.....
Its raing out so i dont know if its leaking but the fluid checks ok..... my dad is gonna kill me!!!!!!~!
Old Jan 14, 2007 | 06:53 PM
help!!!!!
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH...
lol
Old Jan 14, 2007 | 07:26 PM
anybody have an ideas..... help!!!
Old Jan 14, 2007 | 07:41 PM
phox_mulder's Avatar
Patience is a virtue young grasshopper.
Many folk remember the Sabbath Day and keep it holy,
others only have internet access at work,
others are too busy watching football.
One must wait more than 30 minutes between posts.
phox
Old Jan 14, 2007 | 07:42 PM
BigDave12768's Avatar
Take it too Triangle transmission by Burgin Prkwy or go to reliable Transmission in Holbrook on 139 by the Randolph line
Old Jan 14, 2007 | 07:50 PM
are you from quincy bigdave? I would like to convert to a manual, 1) its cheaper, 2) its more fun for me, but you knwo any junkyards that would have a 5speed cummins?
Anyone have any experience with this type of proble that i stated above
Old Jan 14, 2007 | 09:03 PM
volly818's Avatar
Have you checked to see if there are any codes? Maybe you will get lucky and just a sensor went bad.
Old Jan 14, 2007 | 09:55 PM
I am from Weymouth. Its not a cheap to do that change over. Plus I think you also might have to change out the ECM. But call middleboro auto salvage and Clemys would be your only options. RC Truck in E.Bridgewater may have something but I doubt it. But with your mods a regular rebuild will not hold the power you are putting out. You will probably have to find something on the net.
Old Jan 14, 2007 | 10:10 PM
53 willys's Avatar
Reverse takes twice as much fluid pressure to engage as the forward gears.
you may have lost your trans pump.
sounds like you need to take it to a trans shop for diagnosis.
let us know what you find.
Old Jan 14, 2007 | 11:11 PM
mr T's Avatar
don't the 96's have 47RE's?..ur in limp mode...do a search on limp mode...i forget what the fix is..some sensor or governoor i think....its late i forget
Old Jan 14, 2007 | 11:22 PM
53 willys's Avatar
governor pressure solenoid and the governor pressure sensor
you should check the codes
does key on key off work on the 96's??
Old Jan 14, 2007 | 11:25 PM
mr T's Avatar
thank you 53willys...those are the ones
Old Jan 14, 2007 | 11:31 PM
53 willys's Avatar
I had them go bad on my 01, It did not cause the same problems as above and it never threw any codes the whole time.
those are two cheap parts that you can change your self and save some cash tho.
tranny's can be a pain to diagnose
I had to have a scanner to finally figure mine out.
Old Jan 15, 2007 | 10:58 AM
thanks for all the help, gonna pull it into work today and pull it apart......
Old Jan 15, 2007 | 04:13 PM
well no chance to get a look at the tranny. Im still lost, Mass Diesel said that they will put a DTT in it for 4400 dollars. How is that price compared to any of yall. This is just a moderate built tranny though. I have not heard back from goerend yet though. i called dave this mornig but he was on a test drive.
