3200 rpm spring
3200 rpm spring
Can I use the 366 spring from a 1st gen 6bt with a VE pump
on my 1st gen 4bt with a VE pump to increase the rpm to 3200.
OR-- is there another way to increase the rpm on a 4bt?
Thanks in advance.
Thanks in advance.
Yep, the 3200 RPM spring will work just the same.
You can squeak a few hundred more no-load RPM out of it by backing out the high idle screw, but it's still going to defuel at the same point under load unless you swap the spring.
