Which to buy?
Which to buy?
my and my father both have diesels...even if his is a ferd. But anyway there is a station by me that sells biodiesel, is it truly safe to just run it in my rig? even with the engine mods? I have also herd of different kinds of fuel, b20...are they all the same? thanx
steve
steve
B20 is 20 percent biodiesel and 80 percent #2 diesel mixed together. It's the most common blend stations sell. You can mix it to what ever percentage you want. But with winter coming, stay low, like b50-b20.
I can't say if your truck is going to run it without problem. You need to realize that biodiesel will degrade rubber. Any parts made with rubber will eventually fail ie: westach fuel pressure sending unit. You will need to check with fass if it's biodiesel compatible. Last time I've check, they didn't know since they haven't tested it with biodiesel/blend. So your going to have to make the call. To me with b20 more expensive then #2, it's not worth it.
I have 90hp injectors and I ran a edge ez before it die on b100. It ran pretty strong. Good luck.
Edit: I apologize for this mistake. It was the eliminator pump that was not test for biodiesel not the fass. Sorry.
Eugene
Eugene
I've never done a temp test. I do set a jar of b100 outside and check it in the morning. I recall it started clouding up around 38 degree. I did test a small jar in the fridge and it clumped up at 34 degree. I run low blend so it really doesn't matter on the temp.
Eugene
Yes but they won't protect down to as low of a temp as they do with #2. B100 isn't recommended in cold climates.
Read this http://www.powerservice.com/aeba/
You really shouldn't run over B75 in a common rail engine any time of the year anyways. Depending on the BD's oil feedstock it has a tendency to polymerize (get stringy) with the higher temps and pressures of a CRI engine.
I'll toss this in here in hope that you notice it in this or the nj thread,,,,,,,,, Steve, where exactly is the station by you that is sellin the bio/ bio blend ?
Bradleysram
19
05-12-2009 08:36 AM
Badd Dogg Guy19
14
04-14-2005 09:04 PM
