Fuels / BioDiesel / Diesel Prices Use this forum to discuss your biodiesel information, and to find the best price on fuel.
#2 gel piont
Old Dec 6, 2009 | 06:25 PM
94ram's Avatar
#2 gel piont
at what tempature does #2 gel up?
Old Dec 7, 2009 | 07:07 AM
dott's Avatar
Is this what you are asking about?
From the Amsoil site:
https://www.amsoil.com/storefront/dfc.aspx
"As the temperature drops, the wax naturally found in diesel fuel begins to form crystals. The point at which wax crystals form is known as the cloud point. These wax crystals eventually clog the fuel filter and starve the engine of fuel, preventing it from starting. While low quality fuels may form wax crystals in temperatures as warm as 40°F (4°C), most fuels have a cloud point near 32°F (0°C). The point at which the wax crystals clog the fuel filter is known as the cold filter-plugging point (CFPP). AMSOIL Diesel Concentrate Plus Cold Flow Improver lowers the CFPP by as much as 34°F (19°C) in ULSD."
Old Dec 7, 2009 | 08:19 PM
94ram's Avatar
so im guessing the #2 around here is mixed? its been around 4 to 10F around here for the last week or two and my truck starts fine. im just wondering at what point should i start using additives or switch to #1
Old Dec 7, 2009 | 10:34 PM
STate's Avatar
I use additive year-round. It helps with lubrication of the fuel system. On my 12 valve I run fuel conditioner and/or two stroke oil in the summer time. In the winter I use a fuel conditioner with anti-gel. Either Diesel Kleen in the white bottle or the NAPA brand.
But to answer your question, Ive experienced fuel gelling in temps as warm as +20deg F.
scott
Old Dec 9, 2009 | 06:56 PM
94ram's Avatar
well then i guess im gonna have to start using anti-gel then its been getting down to -10 here and they say its colder in north dakota which i will be at for the next two months
Old Dec 10, 2009 | 01:26 PM
DBLR's Avatar
94ram,
If your buying your fuel at the Flying J truck stop there in Rapid City then its most likely already mixed 70/30 but is still a good idea to add you own anti gel just to be safe. Also its a good idea to carry at least one Qt bottle of Power Service 911 (or some other brand of your choice) under the seat just in case you ever do gel up.
Old Dec 10, 2009 | 08:42 PM
94ram's Avatar
ive been fueling up at safeway since i get member discount
ill be heading up to wahpeton, nd in a couple of weeks so im sure i will definitely use anti-gel there
Old Dec 12, 2009 | 08:23 PM
jkitterman's Avatar
Fill up in ND, it will be blended for the temps already
Old Dec 12, 2009 | 08:41 PM
94ram's Avatar
ok will do
what exactly makes #1 different than #2?
Old Dec 19, 2009 | 06:51 PM
b4black's Avatar
Amsoil is full of poop. They are trying to scare you into buying thier additives.
The highest cloud points you will find for a diesel #2 is +15°F. Most northern climates will have lower cloud point. Additives can only lower the operability of a fuel by about 15-20°F below the cloud point. (The CFPP, measured on a lab instrument, may be 34°F lower, but don't count on that to translate to the real world)
Old Dec 19, 2009 | 06:54 PM
b4black's Avatar
Originally Posted by 94ram
ok will do
Diesel #1 is a little ligher cut of distillate fuel than diesel #2. It will have a cloud point about -40°F. Every 10% diesel #1 blended into diesel #2 will drop the #2's cloud point by about 4-5°F.
K-1 Kerosene and Diesel #1 are essentially the same thing.
Old Dec 21, 2009 | 05:48 PM
DBLR's Avatar
I just looked at Chevron's diesel info and see that the listed CLOUD POINT
°F MAX for Spokane WA from Oct 21 to Feb 29 is +26 and it has a POUR POINT
°F MAX. of -20.
BA05'CTD
16
Oct 27, 2005 02:58 PM
CTDinMT
Jan 9, 2004 09:11 PM
Mallard
14
Dec 17, 2003 06:31 AM
shaft
15
Nov 19, 2003 08:33 PM
mitchkim
Oct 25, 2003 08:55 PM
