Everyone read this,,,you may have a shorted wire!!
Old Jan 4, 2006 | 08:27 PM
  #46
CRXsi's Avatar
Just went out and checked mine,
It was starting to rub as well. Nothing serious yet...but it could have been. I don't have any wire loom at home but I do at work so I'll have to get some tommorow. Thanks everyone for the heads up.
Old Jan 6, 2006 | 01:15 AM
  #47
MonroeDiesel's Avatar
Thank You! mine was rubbing badly I fixed it with some 1/4 wire loom. I love this site.
Old Jan 6, 2006 | 08:44 AM
  #48
Donald A's Avatar
Question
Does anyone know if this is a potential problem for the 2006
Thanks,
Donald A
Old Jan 6, 2006 | 01:44 PM
  #49
shep1's Avatar
Looked at mine the other day and it looks like it could rub through. Have to take care of it soon.
Old Jan 7, 2006 | 12:59 AM
  #50
Bad Ramer Jamer's Avatar
Thanks,
Donald A
So far it look's like 04.5's and 05's. But you never know. Why don't you go look and tell us what you find out.
Old Jan 7, 2006 | 10:03 AM
  #51
C Schomer's Avatar
I checked my 03 and there were no wires against the AC line but the comp. clutch wires were run over a bolt head that was wearing into the wire. The alt./batt wire, between the battery and the air filter box was against the intake heater relay steel bracket and nearly worn thru the insulation. I've had an alt/batt wire short out before and it sure makes a LOT of smoke and it's not fun to fix in a big hail storm - that stuff never happens at a good time! I also need to reroute the ground ribbon behind the starter motor. It runs from the block to the body and is wrapped around a wire bundle. They can all have problems depending on who did the routing. Craig
Old Jan 7, 2006 | 02:10 PM
  #52
Donald A's Avatar
Bad:
Will do, porbably tomorrow, and post results.
Donald A
Old Jan 15, 2006 | 11:08 PM
  #53
CRXsi's Avatar
I fixed my wire rubbing issue tonight, I took some convaluted tubing (wire loom stuff) and tucked the wire into it, I then double wrapped it with electrical tape and finished off by securing it to the AC line by the pressure switch with a zip tie just to prevent it from rubbing,
This picture is from under the passenger side ooking up, the big round grey thing is the oil filter and to the right of the picture you can see the wire has been re-routed and zip tied to the AC line'
It was a matter of time before this would have been a severe isue, thanks everyone for the heads up!
Old Nov 3, 2007 | 01:09 PM
  #54
Chowderhead72's Avatar
Can someone repost the pic of what to look for?
Old Nov 3, 2007 | 01:53 PM
  #55
na4now's Avatar
Please.
Why isnt this a sticky?
Old Nov 3, 2007 | 02:32 PM
  #56
TallTom's Avatar
Go to Windscreen's page the photo is in his photo's great job!!!
Old Nov 3, 2007 | 03:07 PM
  #57
packard8's Avatar
Thanks for the tip, but do you have a URL for Windscreen's page? I don't know who or what he/it is.
Thanks!
Old Nov 3, 2007 | 03:34 PM
  #58
Buddy7311's Avatar
First page of this thread. Last post. Check user name then view public profile.
Old Nov 3, 2007 | 06:01 PM
  #59
CRXsi's Avatar
Here is the picture reposted....there are other pics in my gallery
You can see the oil filter and AC compressor. The wire in question is the one with electrical tape and you can just make out the zip tie securing it to the AC line so it doesn't continue to rub even with convoluted tubing and tape. Mine was definitely showing signs of wear but not to bare wire yet. Others have reported some driveability issues when it rubs through.
Old Nov 3, 2007 | 11:45 PM
  #60
KMKDiesel's Avatar
Just started a new thread my buddies 05 is acting crazy just like the symtems on here I think this is it I will check it out in the morning
