'93 D350 steering question
Old Oct 31, 2020 | 08:37 PM
Sigogglin's Avatar
I'm looking to swap a '49 ford f4 cab on to my D350. One issue is that the cab is about 10" narrower than the original cab, that coupled with the steering box on the outside of the frame rail makes for a sharply angled steering column. I know I can go with a gear/chain driven solution, but I'm wondering if I can swap the front/modify the front end to get the steering box on the inside of the frame rail like a 2nd gen? The existing front end needs to be completely rebuilt.
Maybe it is better askes what options are out there?
thanks
david
Old Nov 1, 2020 | 10:39 AM
JMZ's Avatar
JMZ
thanks
david
I have no idea but I would definitely be interested in your progress.
Old Nov 1, 2020 | 01:18 PM
BHD's Avatar
BHD
Sound line a nice custom build.
Remounting the steering box to the inside would take a lot of re-engineering of the steering geometry. I would try to mock up something using parts from Flaming River, Far From Stock or another aftermarket steering supplier.
Or you could buy a front frame section from a 2nd gen in a wrecking yard and weld that on to your D350 back half.
Chain drive sounds sketchy, no way I would pass any kind of chain drive steering for safety inspection.
Good luck, and keep us posted.
Old Nov 1, 2020 | 01:38 PM
Sigogglin's Avatar
This is what was afraid of. I'm looking for a 2nd gen donor as a backup plan and then just sell my D350 parts
This is the steering solution I found. Seems legit. . .
Wizard Fabrication I Steer Clear Offset Steering Coupler | 916-736-0110
david
Old Nov 1, 2020 | 01:44 PM
Sigogglin's Avatar
This is how I bought it from the guy that first started the swap. I'm now trying to figure out how to move forward. As you can see the cab is quite narrow.
Old Nov 1, 2020 | 04:21 PM
BHD's Avatar
BHD
That is a really nice project. I've been thinking about doing the same with a post war Dodge cab I have.
That Wizard Fab unit seems solid. I wouldn't be afraid of that. I didn't know that style of offset steer set up was available.
Thanks man!
Old Nov 3, 2020 | 12:13 AM
u2slow's Avatar
Is the Dodge frame otherwise a fit for the cab?
A Chevy C30 frame (73-87ish) is 4" narrower for most of its length, and a couple inches narrower at the front. Steering box is still outside the frame... but every bit helps.
The front suspension & brakes are also a much better match for the weight of the 6BT.
Old Nov 3, 2020 | 04:24 PM
Sigogglin's Avatar
yes the dodge frame is a good fit besides the steering. Moved the engine mounts back about 3 inches to get a bit more clearance up front for the radiator and intercooler. Now looking at a water/air intercooler option I saw on Jay Leno's show. It looks promising.
Old Nov 3, 2020 | 07:26 PM
u2slow's Avatar
Non-intercooled is usually fine unless you're towing, pulling, or dyno-champ.
MrFusion
Jul 4, 2014 06:51 PM
1bad93
Aug 11, 2011 07:09 AM
CASHESVALLEY
20
Dec 27, 2010 09:48 PM
joker834
Jan 16, 2007 08:22 PM
ramcummins
Apr 30, 2004 08:15 PM
