Bellhousing interfering on 24v pressure plate?
Old Dec 13, 2020 | 04:47 PM
Chummins24v's Avatar
Hey ya'll I put a 24v in a 94 chevy k2500, I put a 13 inch southbend clutch on it and now my bellhousing interferes on the pressure plate, it is a nv4500 transmission and the bellhousing that came with seemed to be right as it bolted right up with no clutch installed on the engine.
Old Dec 14, 2020 | 02:27 PM
u2slow's Avatar
Is it the correct flywheel? Are you sure its a bell/pressure-plate interference? Or maybe its disc/flywheel interference? Is the disc in backwards?
FWIW, I've noticed some of the 13" clutches have a larger diameter damper spring package, and that requires a flywheel with a larger diameter rebated area in the center.
Will need to know the:
- nv4500 source/application
- bellhousing source/application
- flywheel source/application
- southbend clutch application
Old Dec 14, 2020 | 02:51 PM
Yes I am sure the bellhousing is hitting the pressure plate. It is a sbc 0090 clutch and is a push type I believe. I can post a picture later but I can see marks on the pressure plate and scratches in the bellhousing from it, I had heard before that sometimes the pressure plate can run a pretty tight fit in there but I never expected a clutch advertised as a stock replacement to hit.
Old Dec 14, 2020 | 02:52 PM
Old Dec 14, 2020 | 03:39 PM
u2slow's Avatar
This clutch?
https://www.southbendclutch.com/clutches/0090-10128/
What engine plate (adapter) is on the back of your cummins? Stock NV4500 uses the thicker one.
Old Dec 14, 2020 | 03:42 PM
Yes that clutch, ill have to take another look at my adapter plate. Hopefully thats my issue thanks I didn't think of that as the engine was from and automatic I believe. But that should give me the space I need if it is the automatic one
Old Dec 14, 2020 | 05:49 PM
u2slow's Avatar
Auto or std is the same. 1stgen vs 2ndgen is different... 2ndgen is thicker. Diesel NV4500s came with the 2ndgens.
Old Dec 14, 2020 | 06:18 PM
Ah okay, sorry this is my first swap. I just measured 1 1/2 inch about on my adapter plate, I couldn't see exactly what you got in that picture on yours though
Old Dec 15, 2020 | 08:46 AM
u2slow's Avatar
That's the thin one. The 2ndgen plate is almost 2.5"... it also requires its own starter motor.
Old Dec 15, 2020 | 08:52 AM
Alright thats no problem. Thanks a lot for your help! Hopefully this is what I need
Old Dec 15, 2020 | 10:47 AM
Good call u2slow. That should fix him right up.
Subliminal
Dec 19, 2010 09:20 AM
SlowSmoke
Nov 23, 2009 02:25 PM
Silver Ram
Mar 25, 2009 04:57 PM
Hercules
0
Nov 6, 2007 05:42 PM
Rick_Orcutt
Apr 30, 2006 02:34 PM
