1St gen 12 valve in a 99 1500 2wd?
Old Mar 5, 2009 | 03:32 PM
nintythree2wd's Avatar
I bought a new 2wd 1500 in 99.other than the normal trans issues for that year it's been a good truck.I put a fab tech 3" lift on it a while back,which has heavier springs than stock.I also replaced all balljoints with moog grease fitting type ball joints.Then I ran across a 93 d250 with 127000 original miles for a grand,estate sale couldnt pass it up. runs great but it's beaten up bad.how hard would it be to convert my 1500 to a 12 valve?I guess the ? is will the fab tech suspension hold up?Thanks
Old Mar 5, 2009 | 06:15 PM
Yeah, the suspension will be fine. If it sits too low you can use diesel springs.
Getting the dash to work will be a challenge.
Check your state laws before you start swapping, quite a few states won't let you install an engine older than the chassis.
92GhostRyder
Sep 16, 2018 12:02 PM
92smokin blacky
Jun 1, 2010 12:03 PM
pulltilbroke
Apr 10, 2009 02:08 PM
dhendry
Introductions / New People
Mar 12, 2008 09:03 PM
77machomopar
Dec 27, 2007 11:05 AM
