Where to start?
Old Jul 28, 2005 | 02:56 PM
Kroner's Avatar
Where to start?
This is short notice but I have a chance to pull in a few hours and I would like to know what gear to pull in. The truck is a 5 speed with 4.10s and 35 inch tires?
Thanks
Adam
Old Jul 28, 2005 | 03:13 PM
fordper4mance's Avatar
Depends on how hard you want to be on your truck. If you think you have the power and that the clucth will hold then go with 3rd low range. that will give you your best shot to do well but is definatley hard on a non-pulling clutch. If not that try second low range. You will have less ground speed but you will be alot more likely to have a clutch left at the end of the run. Good luck!
Old Jul 28, 2005 | 04:35 PM
fearthedeere's Avatar
if ya dont pull in 3 low do 2 hi
Old Jul 28, 2005 | 05:48 PM
joefarmer's Avatar
3rd gear, 4WD lo range, spool to ~2500 rpm, let out the clutch slowly... make sure you're all the way off the clutch by the 75' mark. Let us know how it goes...
brandon.
Old Jul 29, 2005 | 01:18 AM
Kroner's Avatar
Well I took last place at 221 ft. I started in 3 lo and killed it right away but then went to 2 lo . That was the most fun ive had in a while. Thanks for all your help everybody.
Adam
Old Jul 29, 2005 | 01:48 AM
cumminsdriver635's Avatar
Hey dont feel bad. I also took last at our local fair, but its one of the funnest things you'll ever do, and next time i pull i dont intend to be last because ill have more goodies by then
Eric
Old Jul 29, 2005 | 07:59 AM
and ill just beable to pull.
Old Aug 1, 2005 | 10:17 AM
haloman's Avatar
I was sitting at about the 275 foot mark. There were some nice trucks there. Kroner you didn't do too bad. The duramax that won is from my area and has also won the henderson and union county fair pulls over in KY. That truck defiently has sleeper written all over it. I knew it was over when i seen him pull up.
Old Aug 1, 2005 | 10:23 AM
Are you talking about Ryan Uptegrafts white d-max?
Eric
Old Aug 1, 2005 | 10:33 AM
haloman's Avatar
No this is a red d-max with a amber warning light on top. It is driven by an older fellow
CoolumConst
Oct 11, 2008 10:00 PM
bfarrell
Nov 30, 2005 03:23 PM
Erik Dlux
24
Dec 8, 2004 07:26 AM
502502
Nov 27, 2004 09:15 PM
eng208
Jul 14, 2004 06:21 PM
