Two Wheel Low?
Two Wheel Low?
At the July 21st pull they are adding a two wheel drive class. I might run in this class also just to help have enough trucks for the class. My question is how can I lock my 4X4 2005 dodge truck into TWO WHEEL LOW ? Pull a vacuum line on the front axle or is it electic ?
When I pull the vacuum line do I need to pinch it off, leave it hang any details ? About the cut tires, unless they let you pull in the open class I believe you have to pull with DOT tires. I'm also looking forward for you to move down here and start pulling with us. Help us promote this sport like it is up in Ohio and surrounding states.
yes, i forgot the AAM axle dosent have the CAD on the axle, pull the front shaft, if we get a following it will be as big as it is here in the midwest. we got enough trucks down there, just no one ever has really gotten into it, like i said, i am bringing a complete set of rules for both diesel and gas classes, as much as people hate them, gas trucks make up a large part of pulls up here, i plan to run in the open class with cut tires. i just got to get a set of 15x14 steel wheels for the rear of the truck to run my 31x15.50x15 tires on.
