Tonight at the track
Old Oct 13, 2006 | 08:08 PM
I SPEED's Avatar
R/T....194
60'...1.74
330...5.13
1/8...8.04
MPH...83.10
1000...10.60
1/4...12.77
MPH...103.77
Backed this up with a 12.93@104.41
Had trouble hooking up off the line...4WD launch at 20psi and spinning all 4 tires.
All in all, pretty happy with these numbers.
Old Oct 13, 2006 | 08:45 PM
CTD2001's Avatar
Nice job Doug, sounds like your truck is running great, Did you get the MAD ECM in yet?
Old Oct 14, 2006 | 06:12 AM
I SPEED's Avatar
Catcher is in, as is the RAD switch which made a big difference.No more defueling off the line.
Old Oct 14, 2006 | 06:44 AM
Geico266's Avatar
Sweet times! Congrats!
Old Oct 14, 2006 | 09:00 PM
CTD2001's Avatar
What does the rad switch do?
Old Oct 15, 2006 | 03:42 AM
Sea Bass's Avatar
WOW!! Those are great times. Runnin' in the 12's with just a ps62 is very impressive! What HP do you think you're at? 475?
That's great! Most trucks I see runnin' in the 12's on 35's are atleast mid 500's or more.
Old Oct 15, 2006 | 07:35 AM
I SPEED's Avatar
The switch prevents defueling when launching and when the truck shifts from 1st to 2nd. BD makes it...got it from Scott.
As far as HP numbers, I'm thinking 500+...we're not back on the dyno until Nov. 11. I'll post the numbers then.
Old Oct 15, 2006 | 05:50 PM
CTD2001's Avatar
I thought that the Catcher had the feature that the RAD has? Am I wrong? Can you tell a difference when driving on the road with it, or is it a drag racing only feature? I am interested about it
Old Oct 15, 2006 | 05:55 PM
masonic-dodge's Avatar
Try a set of 285s and you should knock 2/10ths off.
CRIS
Old Oct 16, 2006 | 06:23 AM
I SPEED's Avatar
CRIS
Truck is over geared now with the 4:10s. I really need a 36" tire under it.
Mike, Scott said that the Catcher does not prevent defueling. Truck went 12.9 with the switch off, then went 12.7 with the switch on.
CTD2001
Aug 22, 2009 10:03 PM
Billm2004
May 10, 2009 03:34 PM
imelmo
21
Mar 28, 2006 12:27 AM
getblown5.9
Apr 11, 2005 09:11 PM
