Daily Driver 785/1500+++
Old Sep 14, 2006 | 10:56 AM
redstreak's Avatar
Just figured you guys would like to see this video. Check out the water pouring out of the old 53 block!!
http://powerbypoole.com/785%20hp%201500tq.wmv
Old Sep 14, 2006 | 11:30 AM
Mcmopar's Avatar
I musta missed it??
Old Sep 14, 2006 | 11:31 AM
Mcmopar's Avatar
Saw it that time!! Where is Denton NC?
Old Sep 14, 2006 | 12:14 PM
JD730's Avatar
I'd say it has a small leak.
Old Sep 14, 2006 | 12:43 PM
95ram's Avatar
I'd say it has a small crack, oh, about 8" long.
Old Sep 14, 2006 | 04:37 PM
dieselfan's Avatar
when did this happen? is this the truck that runs 11.54?
just curious, dieselfan
Old Sep 15, 2006 | 08:27 AM
redstreak's Avatar
The crack appeared before Rockingham's 11.54 run and it was only about 3in long. I decided to go ahead and do it and ran the 11.54. The crack didn't like that at all so now I am left with this. Any of your guys know anybody at Cummins that will help me out with a block?? Any suggestions would be a great help for that matter. Repair isn't even an option.
Old Sep 15, 2006 | 08:55 AM
haloman's Avatar
Man that looks like you busted a rad. hose but is was the block!!!! i think most people stop running them when they see a crack.
Old Sep 15, 2006 | 11:11 AM
king d's Avatar
Ad removed site violation
Last edited by Lary Ellis (Top); Sep 18, 2006 at 10:16 PM. Reason: Ad removed site violation
Old Sep 16, 2006 | 10:59 PM
dodgeguy71's Avatar
I know there is a place in Texas that repairs blocks....I know, I know, but listen. We had a 3508 Cat out of a D11. The counter weight bolts broke and spit this 50ish, 60ish pound counter weight out the side of the block. The block alone was around $50,000 if I remember correcty. There was a GIANT hole in the side of this block. We sent it off and a couple weeks later got it back and you could not tell unless you looked inside from the bottom. It was an 800hp motor and 2200-2300 ftlbs of torque. Just a thought, but I guess if the 53 block is already bad....from the factory, would it be worth it or strong enough?
Old Sep 16, 2006 | 11:00 PM
dodgeguy71's Avatar
Sorry, not to sure of the name on this place, just knew it was in Texas somewhere.
CTD_Neil
18
Nov 7, 2005 09:18 PM
bharring
Apr 29, 2004 02:55 PM
kingofdodge7131
Aug 31, 2003 12:20 PM
hellotbone
16
Nov 6, 2002 03:18 PM
