Twins, Twins, Twins, Twins, Twins............
Old Jun 8, 2011 | 06:58 PM
  #181
1-5-3-6-2-4's Avatar
sprung disks verses solid disks.
Old Jun 8, 2011 | 07:50 PM
  #182
Tate's Avatar
Thats more drivetrain vibration, both my 3600 and my first 3250 had the familiar noise with the clutch pedal pressed. My new 3250 doesn't make that noise, it has rubber isolators between the floater plate and flywheel.
The slower shifting and the rattle when lugging it (I find it is usually only in direct drive) I think is part of the DD experience.
Old Jun 9, 2011 | 04:08 PM
  #183
Tate's Avatar
Originally Posted by StealthDiesel
Nothing major, Tate, but I hate the rattle at idle with the pedal pushed in, still slow to shift, & it really rattles the tranny if I lug it below 1800 rpm or so with the trailer on the back.
The pedal pressure is fine (near stock), my wife can still drive the truck empty but you always know it's there.
The latest generation of SB dual disk's don't rattle at idle anymore. Brad (Goatbrain) has a newer gen street SB DD 3600 & it's quiet at idle with the pedal pushed in.
Do you have a fluid damper on your truck? Makes a big difference with the harmonics in 5th.
Old Jun 9, 2011 | 07:49 PM
  #184
StealthDiesel's Avatar
My SB DD 3250 has 2 or 3 springs & 2 or 3 polyurethane pucks per clutch disk. It's a compromise vs. solid hubs.
The SB documentation that came with the clutch had all kinds of warnings to NOT lug the engine with this clutch.
I don't have a fluid damper, Tate. Do you really think it's worth the near $500 for one?
Next time we get together I wouldn't mind comparing clutches.
Old Jun 9, 2011 | 09:13 PM
  #185
Tate's Avatar
Makes a big difference, I noticed the biggest difference with my solid hub clutch (whats in my dually). Worth every penny IMO.
Old Jun 9, 2011 | 11:00 PM
  #186
goatbrain5.9's Avatar
I really don't mind the shifting with my 3600. What concerns me is the noisy throwout bearing and crazy knock I have with the clutch engaged in neutral. I've lugged my truck before and it really doesn't vibrate any worse than the old clutch. My old single disk and this new dual practically weighed the same when I had them out.
Old Jun 10, 2011 | 01:34 AM
  #187
Tate's Avatar
If your floater disc doesn't have those bushings, then you'll get that 'throw out bearing' noise. Its normal, nothing wrong with the bearing.
Old Jun 10, 2011 | 10:05 AM
  #188
Don't all the new style clutches have the bushings?
Old Jun 10, 2011 | 06:33 PM
  #189
Tate's Avatar
I don't know when the change over was, I guess ask the guy who put yours in. I bought my last clutch last summer and it had them.
Old Jun 10, 2011 | 06:55 PM
  #190
Mike Holmen's Avatar
The Guru
I have a friend that just put a SB OFE clutch in a 01 truck 4X4, the clutch is half worn out. I had to adjust the pedal so he could shift the gears again last weekend. The clutch is about three/four months old. He hauls a 14-16k trailer, the truck is bone stock except for a set of 60HP sticks, but of course I built the engine, so its more than a stocker
Old Jun 10, 2011 | 08:09 PM
  #191
Me and Steve put it in, it was the newer style that has the rubber pucks in it. Either way something sounds like it's gonna blow under my truck haha
Old Jun 10, 2011 | 08:14 PM
  #192
Tate's Avatar
Well, it is a common rail. Its what they do.
Old Jun 11, 2011 | 10:18 AM
  #193
pistazie's Avatar
Ouch, LOL
Old Jun 11, 2011 | 12:25 PM
  #194
dvst8r's Avatar
He only speaks the truth... Sometimes that truth hurts.
Speaking of which did you get yours put back together? I heard through the grapevine yours followed that unfortunate path that most CR's eventually do.
Old Jun 11, 2011 | 04:31 PM
  #195
pistazie's Avatar
It did, I've got Stephen from Khaos Kustoms putting it back together. Bought a shortblock and the head needed work post-mortem.
