needs tools
Old Jul 1, 2012 | 02:27 PM
Red_Angus's Avatar
needs tools
i was wondering if there was somebody nearby who has some tools to help me figure out why my 99 is surging at idle. i am looking for a way to test my fuel pressure. i havent done any of the little stuff like filters.
Old Jul 5, 2012 | 01:21 AM
Dr. Evil's Avatar
Red, I can probably help you out if its not too late. That being said, Im definitely no expert. Im in leduc...
Changing the fuel filter is definitely a good place to start.
Old Jul 5, 2012 | 10:00 AM
Mike Holmen's Avatar
The Guru
Do you have any tach speed? Is it steady? You have fuel leaking or done injector exchanges as of late?
The 99 trucks, the tach sensor is off the crank and under the VP, just below the stock lift pump. The sensor under the VP is for the tach.
Are you getting any codes?
Old Jul 5, 2012 | 01:51 PM
Red_Angus's Avatar
i changed the filter. it was Black. probably a bad sign.
no codes, no noticeable leaks, idles about 700 rpm without any waver on the tach. i may have posted on here too soon. though i dont know how new any of the parts are, the trucks got 375000kms on it and i cant imagine its still got the origianal vp44 or lift pump.
when its warm at idle there seems to be a small noise. for all i know its the valves. i dont have a barring tool for adjusting them. i havent gone in there either, though i think the recomended service is every 24000 miles.
oh there are codes, for the turbo: p0234 and p0236.
Old Jul 5, 2012 | 04:56 PM
Lil Dog's Avatar
With the turbo codes for over boost and erratic level might just be dirty sensors. pull the MAP sensor out and clean it off with some electronics cleaner, might fix that up.
http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
The barring tool is optional, I use the alternator to turn it over in reverse rotation to set the valves. A little tricky the first time, but is pretty simple. I set mine every 100,000 km.
Old Jul 25, 2012 | 08:12 PM
Red_Angus's Avatar
finally made it home long enough to put some time into the 99. found out i need a 1 1/16 deep socket for the map sensor. but i was able to pull the IAT sensor and i put my K&N filter back in. those seemed to have gotten rid of the turbo codes.
Old Jul 26, 2012 | 04:28 PM
roxxx's Avatar
Does it have stock exhaust if so drop the pipe off after the down pipe and run it ... Very good chance you have plugged pipe.
common on the old models with the small kinked exhaust . this is right from Cummins we had one of my old ones on the dyno at cummins and had a pressure gauge on the down pipe ....back pressure = over boost code
Old Jul 26, 2012 | 05:45 PM
Red_Angus's Avatar
it does still have the stock exhaust system. the over pressure is from the cat plugging off? or from an improper bend. it lost the over axle bends due to rust, it just happened to be easier to put a 90 on the muffler so it doesnt heat up the axle as much. i dont think im ready to put an exhaust system on the 99, recent family additions have made an extended cab quite cramped and im not sure how long i plan on keeping it.
Old Jul 28, 2012 | 01:50 PM
Dr. Evil's Avatar
There shouldnt be a cat on a 99. It should be a resonator not sure if they will plug like a cat but probably not.
I should have a 1 1/16" deep socket (I will have to check though) and some contact cleaner Red Angus if you still need to clean your MAP.
Old Jul 29, 2012 | 10:04 PM
Dr. Evil's Avatar
Ive got a socket at home if you need it bud
Old Jul 30, 2012 | 09:18 PM
Red_Angus's Avatar
Now that the rains started again. i should be home for a couple of days. if you could pm me we should b able to work something out
Old Jul 30, 2012 | 10:02 PM
Dr. Evil's Avatar
Sure...
Old Aug 6, 2012 | 02:40 AM
Dr. Evil's Avatar
left a message with you last week.....didnt hear back and you dont seem to accept PMs.
Old Aug 6, 2012 | 08:07 PM
Red_Angus's Avatar
yeah, sorry about that. ive edited my options to allow for PMs.
Old Aug 7, 2012 | 01:17 AM
Dr. Evil's Avatar
no worries. The offer is still open but I likely wont be available for much of this week.
Mcmopar
Mar 8, 2004 09:08 PM
corey
Feb 14, 2003 02:28 PM
fboese
0
Dec 10, 2002 04:01 PM
Nov 4, 2002 12:03 PM
