help find timing tools
Old Feb 14, 2003 | 12:50 AM
corey's Avatar
im new here and was wondering if anyone could tell me were to find the stuff to check my timing on my 89 ctd
Old Feb 14, 2003 | 01:58 PM
gunracer1's Avatar
Re:help find timing tools
just loosen your pump up and push it towards the head. if you look at the side of your pump you will see a witness mark, as in a line on the cover and a line on the pump housing. raise the pump up a 16th of a inch or a bit more. yea, real lotech but it works. but the lower bolt on the foward part of the pump can be a pain to get to. mike
Old Feb 14, 2003 | 02:28 PM
Monty's Avatar
Corey, welcome to the site.
Here is a thread that should help you when advancing your timing. As gunracer said, the bottom bolt is a pain to get too. I took a 13mm wrench and bent it into the shape of a "C", this worked fine. However, Piers sells the C shaped tool if you want to go that route. The stock timing mark on your pump flange and the gear housing should be 1.35mm for a non intercooled truck. 1/16" will give you 1.4-1.45mm advance. Whereas 1/8" over the stock mark on an intercooled truck will give you the same.
The above mentioned is the quick way to do it. If you are looking for a more precise measurement, Snap-On or Miller Tools sells the dial gauge and adapter that is needed to screw into the back of the pump.
Monty
Skip H
May 21, 2010 06:30 PM
Southtowns27
Aug 11, 2008 07:25 PM
GR40RCapri
Jun 25, 2006 12:53 AM
dieselman24
Apr 25, 2004 01:49 PM
