"special" tools for injector job
Old Nov 3, 2002 | 08:03 AM
willyslover's Avatar
Re:"special" tools for injector job
a small screwdriver [4" or so like the pocket clip ones] works great..another would be a small pick [dentist style]
the long bolt from the air horne fits the injector and gives ya something to grip ... I have used a pair of pliers and just wrap the oval open area of the plier jaw around the bolt and a wrench / small ball pien hammer to tap on the pliers jaw and wala it's loose
PULL THAT TUBE FIRST !!!! just needs to come out a little bit to clear the injector
NO EXTRA TOOLS NEEDED for this job that you stated above.......but a short 19mm wrench or a 19mm flair fitting crows foot wernch is handy for #6 injector line but not manditory
another thing....make sure you get the copper washer from the old injector bottom out...and you'll need a bit of assembly grease to hold the new washer on the tip of the new injector
.....all else pretty straight up
Old Nov 3, 2002 | 08:20 AM
JHansen's Avatar
Gary's right on the mark-we modded a 3/4&quot; (real close to 19mm) wrench a little to make torquing #6 a little easier but other than that (and the 19mm crowfoot that I had bought before) nothing special is required.<br><br>Jason<br>
Old Nov 4, 2002 | 07:25 AM
JHansen's Avatar
Smoke wrench or reciprocating saw! :P :'(
Old Nov 4, 2002 | 09:20 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I saw a guy disconnect the injectors then he cranked the starter, launched them babies right on out of there no fuss no muss!. Don't know that I would recommend it, but it worked.
Old Nov 4, 2002 | 11:41 AM
Admin Team Leader
[quote author=Gear Poet link=board=7;threadid=6542;start=0#61717 date=1036425192]<br>Good advice, Top, for extremists who are out-of-warranty. That the same guy you recommended to me? <br><br>(Just kidding. )<br><br>GP<br>[/quote]<br> No that was my brother in law ;D They were trash injectors to him anyway so he let them rip! I would be a bit more careful with my own, but he said it sure does wonders for that one stubborn one you come across
Old Nov 4, 2002 | 12:03 PM
ridofpwrstroke's Avatar
I used a crowbar that a buddy ground out. You put a notch in the top to hook the bolt and it worked without a problem. Great to pry with.
crossy
Jul 12, 2010 04:01 PM
guhfluh
23
Mar 3, 2010 08:44 AM
sallyman1
Feb 8, 2009 09:05 PM
Mcmopar
Mar 8, 2004 09:08 PM
