Fuel Mileage
Old Dec 18, 2012 | 09:51 PM
Tate's Avatar
Fuel Mileage
Anyone else seem to have taken a bigger hit from the winter fuel this year than previous? I was running 18-19 mpg all summer, last tank was 14, and this tank is shaping up to be worse. I'm wondering if its the fuel, or the truck.
Old Dec 18, 2012 | 09:54 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
There is one thing I notice in the last month....I seem to be burning way more fuel once I switched from Husky diesel to Super Store diesel...
Old Dec 18, 2012 | 11:11 PM
winkdemon's Avatar
were you buying your fuel tate ?
Old Dec 19, 2012 | 11:57 PM
Tate's Avatar
Co-op in Airdrie, generally. I had good luck with Fas Gas in Devon as well. Those have been my two fuel up spots for the last year.
Old Dec 20, 2012 | 08:43 AM
2006BLKMegacab's Avatar
I have noticed a bit more of a drop off than normal but not that big and all I burn is co-op fuel out of my tanks at home so it takes me a bit of time to get from summer fuel, through a tank of their "fall blend" to full winter fuel
Old Dec 20, 2012 | 09:36 AM
winkdemon's Avatar
I am still running summer fuel , so i have not noticed a differents , but i have the same problem in the summer time on my dually , come to find out i had a bad lift pump , so that would be something to check if you have not done so already
Old Dec 20, 2012 | 07:41 PM
Tate's Avatar
I could check it easily enough. Had the FP gauge hooked up about a month and a half ago, it was 40+ psi still. I'm gonna try a different station when I gotta fill up next.
Old Dec 20, 2012 | 10:06 PM
Mike Holmen's Avatar
The Guru
Tate your espar must been burning up a bunch of fuel.
I've noticed the usual fuel mileage drop from summer to winter as well. Some winter fuel is worse than other stuff. Could be from extra engine idlin, I typically run my truck more during the winter than the summer months.
When I'm working during the -28 and colder stuff, typically I just left my truck running 16-18hrs a day, for 4-5 days a week, so its hard to get a decent fuel mileage number.
Old Dec 20, 2012 | 11:22 PM
Tate's Avatar
I have gone through close to half a tank in 200 km. I know how much the Espar uses. I was able to run it for an hour on a Snapple bottle of kerosene. I run it for 2 hours a day, roughly. I noticed my boost was close to 10 psi on the highway and egt's were 7-800. Back in the summer, I was typically running low 600's and about 5 psi. I have a few things to look into.
On another note, my dually is leaking oil out of 5 of the 6 exhaust ports. Huzzah!
Old Dec 20, 2012 | 11:29 PM
When I drove to your place...I burnt close to 1/4 of a tank on the Deerfoot 500...There and back....
Oh well... the world is going to end on Friday...So who cares...
Old Dec 21, 2012 | 09:53 AM
The Guru
I'm still waiting for my espar to show-up honestly I don't track my fuel mileage during the winter. Maybe I should, found out that my 2010 transmission just had a sensor issue.
I guess that the GT42 is about as big you can go with a stock 53 block running a 13mm pump, stuff you find when trying to make her purdy again.
The dually really should be 24V deleted and have a 12V under the hood. Tate, I do have a spare freshly ported 12V hamilton head, oversized valves and springs stilling at Dave's. I also have a bunch of 53's blocks/cranks I can give ya so you can start the dualy build-up. Probably have six or so of those 53's.
Old Dec 21, 2012 | 06:06 PM
Tate's Avatar
I'll pass on the Hami head, I'll wait to see how that new aluminum 12v head pans out. I've got my extra 12v that will be getting a rebuild over the next while. I think its the valve seals, but I haven't pulled the valve cover yet to see. I really don't care at this point, the truck is going to be in the garage until it comes apart anyway. Its a mock-up piece currently.
zack birge
20
Jul 11, 2008 10:29 AM
slowstang232
Mar 31, 2008 08:23 AM
snowmanx
Nov 9, 2007 05:34 PM
Kman9090
Sep 19, 2006 11:25 AM
TxDiesel007
17
Jan 17, 2006 02:54 PM
