Drag Wars
Old Oct 14, 2009 | 09:56 PM
  #346
Dr. Evil's Avatar
He probably had to get a paper route after finding out how much this is going to cost....
Old Oct 15, 2009 | 08:23 AM
  #347
Mike Holmen's Avatar
The Guru
A 12v engine would be a cheap upgrade for the truck and you probably could save some money on the NOS fills I have to get a few shots at the CR guys when I can.
Old Oct 15, 2009 | 09:14 AM
  #348
morkable's Avatar
Hey guys, been busier than a 2 bit hooker on saturday night. Been working on my dads old truck this week, gave it to my son. He is up here right now, he's going to drive it back tomorrow morning... did a tuneup on it last night,, finished the plugs wires, cap and rotor and battery,,now the darn truck wont start,, typical of my luck. Of course I bought all the parts last year so I cant return them. I am thinking it must be either a bad cap or rotor..
Old Oct 15, 2009 | 12:43 PM
  #349
ccmckee's Avatar
Geez Kevin if you and Mike ever got together you could probably break something by just looking at it Sorry couldn't pass that one up, hope you get it figured out.
Old Oct 15, 2009 | 12:46 PM
  #350
morkable's Avatar
LOL,, thanks Chris,, but you are probably right on the money there,,, LOL
Old Oct 15, 2009 | 08:23 PM
  #351
The Guru
Chris buddy, you know me way to well. I promise not to look at your truck to hard. Whats the fun on having perfect non broken stuff? I just put in -45 deg'C windshield fluid and a couple gas line anti-freeze. I want to see what will happen. Today, I could only pull around 45psi before I had to slam on the brakes on the way home today. I can't wait to see if the new brew will make more power
Old Nov 26, 2009 | 04:35 PM
  #352
dvst8r's Avatar
Kevin you probably already saw this, but in case you haven't
http://www.competitiondiesel.com/for...ad.php?t=72423
CR Standalone!!!
Rumored to be much easier on the wallet then the bosch versions.
Old Nov 26, 2009 | 06:56 PM
  #353
morkable's Avatar
yeah I have been watching that with much interest! even just 800 more RPM would just fix me right up
Old Nov 27, 2009 | 12:56 AM
  #354
The Guru
A CR crowd might have a chance against the non-electronic group, maybe time will tell. Of course you have to make a pass. My truck is still on the drawing board.
Old Nov 27, 2009 | 08:13 AM
  #355
morkable's Avatar
I seem to do ok against the non electronic guys,,, LOL If this controller works though, I will be able to have enough RPMs to use the Power I already have. That is pretty much my only hold back now
Old Nov 27, 2009 | 09:55 AM
  #356
The Guru
kev, how much timing you using on your truck? I've heard that some guys are using as much as 50 deg's at the higher rpm's. I was told that it helps to make more power.
Old Nov 27, 2009 | 10:05 AM
  #357
morkable's Avatar
Mine is supposed to be about 23 according to what smarty tells me
Old Nov 27, 2009 | 11:18 AM
  #358
dvst8r's Avatar
50 is pretty extreme, but I know that 38-42 is pretty common when either pulling or at the track, on the street most guys tone it down to 28-30.
Old Nov 27, 2009 | 04:09 PM
  #359
The Guru
I was talking to the guy that built the duramax camaro, and he told me that what he runs 50 deg's for timing on the engine. He uses aluminum rods and the crank is offset ground.
Dumb question, is the P7100 pump operates on the static timing or does it automatically increase as the rpm's increase?
Old Nov 27, 2009 | 04:41 PM
  #360
dvst8r's Avatar
P-Pump is static, and that is what I was referring to in my previous reply.
