5th Gear Nut Tool
Old Jul 28, 2010 | 02:59 PM
  #46
Mike Holmen's Avatar
The Guru
Hopefully today, we can get a wee more out the old girl. Got most of the pieces today to complete the project. We are going to have to see how that new 4gsk gov spring works.
Old Jul 29, 2010 | 12:15 PM
  #47
dvst8r's Avatar
Well the silverbullet is on, as is the 4" cobbled together exhaust...
Need to do some afc adjusting, as even with the starwheel half way tight it still fuels to hard at low boost. Might have to put a stiffer gov spring in it.
Made 50psi without any trouble, still have a steady haze, and the pyro still goes past 1600 degrees, but it does take a lot longer to get there.
Going to check for boost leaks tonight after work, and do some more afc tuning. Still has the cupped washers and the full barrel, so there should be a little more fuel left in it as is.
For just a 215 pump, stock dv's, stock rack plug, stock injectors, it seems to fuel not too bad.
Old Jul 29, 2010 | 02:12 PM
  #48
The Guru
Its pretty cool that you can't clean-up the smoke with stock silver bullet 66 on a near stock 97 truck (except the 4gsk springs), maybe we should change that stock silver bullet so you can actually move some air or go to the twin plan
I'm thinking your ride is almost as fast as Tate's dually. We should go down to Race City for a Friday night of fun with our rides.
Old Jul 29, 2010 | 03:32 PM
  #49
Tate's Avatar
I think the racked barrels on a 215 have a lot to do with your issues. Can you say timing retardation?
Old Jul 29, 2010 | 04:46 PM
  #50
dvst8r's Avatar
I guess we have to bump the timing then.
Old Jul 29, 2010 | 08:10 PM
  #51
The Guru
I thought the 215 pump worked pretty decent considering the almost lack of mods. An almost stock truck (except the turbo) making around 450-500rwhp. There not even injectors in the truck.
Might have to get Tate to turn those barrells on that 12v 98 of his...
I was impressed on how solid the truck handled the road in comparision to my trucks. Very nice Truck Brett you came a long ways in a short time, hopefully your trip to Van and back goes smoothly.
Old Aug 3, 2010 | 04:19 PM
  #52
dvst8r's Avatar
Home safe and sound. The silverbullet is a monster on the hiway, but takes some finesse at my current afc settings around town. Made 50-52psi and passing a dream, other then then now slipping clutch and a slight haze. Driving around chilliwack at 33' ASL it made 55 - 57psi and perfectly clear.
Have a few more things that need to be addressed, but nothing major. All in all it was a good trip, and the truck was nice to drive.
Old Aug 3, 2010 | 11:10 PM
  #53
The Guru
So you want to try a different combo out or you staying with the silver bullet? Twins you should be over 60psi and have instant boost. Might need to get in those studs soon.
Just in the little ride I had in the truck, it seems that your truck spools up that turbo better than Tate's truck running his 215 pump. I wonder if its from the timing or from the adjusted barrells that makes that turbo lite better.
Old Aug 4, 2010 | 12:14 PM
  #54
dvst8r's Avatar
I am always willing to try other combos.
Not sure how much data we will get from another combo with the clutch like this, but we will give it a shot.
Meh if the head gasket goes, there are a few heads being O-ringed right now, I will just put one on, and stud it then.
Old Aug 4, 2010 | 03:52 PM
  #55
The Guru
Common buddy, Head gaskets are easy stuff.
Old Oct 3, 2010 | 02:58 AM
  #56
1-5-3-6-2-4's Avatar
yesyesyesyes found my nut socket!!!!!!!!!
in the bottom of a coffee can in the garage i weee taded
Old Oct 3, 2010 | 11:49 AM
  #57
goatbrain5.9's Avatar
hahahahaha, funny how we always put stuff away for storage and forget about them
Old Oct 3, 2010 | 05:40 PM
  #58
Tate's Avatar
My stack of zip cuts were hidden in a similar manner, from when I went up to Kev's a year ago.
LemonDodge
Sep 7, 2019 03:51 PM
LemonDodge
Sep 16, 2010 07:33 AM
abarnar1
Mar 16, 2009 08:27 PM
wadecool
Nov 13, 2006 12:37 AM
MCB56
Apr 16, 2004 11:38 AM
